noise when pressing clutch
davies2005
New User
Unread post by davies2005 »
I have a picasso 1.6 petrol 52 plate and when i press or depress the clutch it makes a noise ive got shards of metal inbet ween the engine and gear box i can select all gears still just a noise when press or depress clutch any ideas
Skull
(Donor 2026)
x 381
Re: noise when pressing clutch
Unread post by Skull »
Could be your clutch release bearing starting to sieze by the symptoms you describe :?:
Gary
x 1488
Or the release bearing is chewing through the pressure plate. Either way, it is box out time....
x 8394
RichardW wrote:Either way, it is box out time....
And very much sooner rather than later...
davies2005
New User
I did think it might need new clutch but didnt want pull everything out first just incase so wanted know what other thought first thanks for your response it looks like i am going to be busy.
flying clutchman
x 3
Unread post by flying clutchman »
you'll probably need the bearing support tube as well, they get chewed up usually. (cheap from ECP)
