Hi all,
What is the correct oil to use in a 2005 Citroen C3 1.4 HDi 16v? No hand book with the car.
Im thinking fully synthetic 5w/40? Will this harm the particle filter if there is one?
Andy
Citroen C3, which oil?
1999 Citroen Xantia 2.0 HDi 110 Estate
2001 Citroen Xantia 2.0 HDi 110 LX
1999 Citroen Xsara Picasso 2.0 HDi 90
1983 T25 VW camper
1994 Mini 1275 35th Anniversary Edition - sold
2007 C8 2.0 HDi 136 Exclusive - sold
Previous AXs
1987 11RE
1987 11TRE
1995 Dimension
1983 T25 VW camper
Previous AXs
1987 11RE
1987 11TRE
1995 Dimension
- qprdude
- My Cars: Renault 5 TS, Renault 14ts, Citroen C5 Mk1, Renault Clio sport, Renault Laguna Privilege. Citroen C5 X7 Exclusive. Citroen DS5 D/sport . And around 25+ other brands from Morris Oxford to S Type jag and most things between.
- x 10
Re: Citroen C3, which oil?
MOBIL 1 ESP FORMULA 5W-30
I think fully synthetic is recommended for DPF engines. Mobil is my choice of oil, but it can be dearer than other brands. Citroen garages would probably use the Total equivalent.
Ask a hundred owners and you will get a fair few different opinions. Some say the cheapest you can find and change it more often ?? Some say any old crap will do, but engine oil is too important to skimp on in my opinion.Higher quality oils tend to suspend carbon particles better than cheap stuff. Basically, you get what you pay for.
Rick.
2013 Citroen DS 5 D/Sport
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
Fully Synthetic LONG LIFE 5 w 30 is the oil to use and is essental to be used too for the Turbo and DPF stuff! Anything thicker will give you turbo problems far sooner then needed..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Lovely,
Many thanks
Andy
Many thanks
Andy
1983 T25 VW camper
Previous AXs
1987 11RE
1987 11TRE
1995 Dimension
1983 T25 VW camper
Previous AXs
1987 11RE
1987 11TRE
1995 Dimension
