fuse
lasthope1967
fuse
Unread post by lasthope1967 »
any one got the fuse lay out for citroen xsara Picasso desire 2.0 hdi 03 just because my water jets are not working found one under right hand side of wing not many inside or any info what fuses do what
xsara Picasso hdi 2.0-------- 2003
x 94
Re: fuse
Unread post by citronut »
i have just looked all through the fuse tables in my daughters Pisssscasoooo hand manual, which was a 2002 car
and it dose not mention a fuse for the screen washers,
although it does say fuse No. B 25A is for the wipers,
this fuse is in the under dash fuse box,
most cars i have worked on the washers are on the same fuse as the wipers,
there is a fuse box under the dash behind the small pocket by the drivers right knee, ( UK RHD cars )
grab and pull/yank the pocket outwards and it will come away,
Regards, malcolm.
x 3283
Re: fuse
On Poxhalls the screen wash is on the same fuse as the boot lock motor. I know the Astra estate does this, and (maybe) Peugeot vans.
lasthope1967
Re: fuse
both front and back wipers work just the screen wash does not,,it worked when I got car only had it 2 weeks,,i have that silly fault were the lights come on by them selfs that's down to Indicator stalk so don't no if that is stoping washer working to,,when I press switch for them it is dead no noise coming from pump
Stewart(oily)
x 35
Re: fuse
Unread post by Stewart(oily) »
I recently had a good result on one of those switch stalks by spraying maintenance spray into the base of the stalk while working the stalk around.
lasthope1967
Re: fuse
I cheers stewart I give it a go,i tried wd40 but no joy,,it seems to work ok on side lights
x 3283
Re: fuse
You might want to try using a proper contact cleaner like these;
http://www.maplin.co.uk/contact-cleaner-25340" onclick="window.open(this.href);return false;
http://www.maplin.co.uk/contact-cleaner-4153" onclick="window.open(this.href);return false;
lasthope1967
Re: fuse
Hell Razor5543 wrote:You might want to try using a proper contact cleaner like this;
I cheers razor i was thinking that me self lol,,got a local maplins down the road thanks =D> =D> =D> =D>
Ben82
x 7
Re: fuse
Unread post by Ben82 »
This is still quite a bit over my head so someone might be able to read this better than me:
But it looks like F14 in the connection board/fusebox under the bonnet seems related, whether I'm correct or not is another matter :)
2004 Citroen C5 3L V6 Auto
Brit living in Sweden with an imported from Germany French Car!
x 94
Re: fuse
it would help to see the txt/ component list with that circuit diagram Ben
it might be a good point to start at the pump plug connector to see if any power is getting there
Regards, malcolm.
lasthope1967
Re: fuse
citronut wrote:it would help to see the txt/ component list with that circuit diagram Ben
is it hard to get at, :cry: :cry: :cry: :cry:
Ben82
x 7
Re: fuse
Malcolm: no text with it, but I find this site very useful:
http://peugeot.mainspot.net/wiringall/index.shtml" onclick="window.open(this.href);return false;
Ben82
x 7
Re: fuse
Possibly not:
Image (click for larger image)
But you might be the better judge of that :) You might be able to attack it from the A section (PSF1 - passenger side under the bonnet, pins 11 and 14 seem to be power and ground respectively for the pump), but I think it'll probably be easier to check from where the pump is (E).
x 94
Re: fuse
wow thats very good Ben,
i hate it when you clever techy types add things like those image's,
very impressed :-D :wink:
Regards, malcolm.
lasthope1967
Re: fuse
cheers ben I get it a bash,,,,
