fuse
- x 94
Re: fuse
i have just looked all through the fuse tables in my daughters Pisssscasoooo hand manual, which was a 2002 car
and it dose not mention a fuse for the screen washers,
although it does say fuse No. B 25A is for the wipers,
this fuse is in the under dash fuse box,
most cars i have worked on the washers are on the same fuse as the wipers,
there is a fuse box under the dash behind the small pocket by the drivers right knee, ( UK RHD cars )
grab and pull/yank the pocket outwards and it will come away,
Regards, malcolm.
OnlineHell Razor5543
- x 3304
Re: fuse
On Poxhalls the screen wash is on the same fuse as the boot lock motor. I know the Astra estate does this, and (maybe) Peugeot vans.
lasthope1967
Re: fuse
both front and back wipers work just the screen wash does not,,it worked when I got car only had it 2 weeks,,i have that silly fault were the lights come on by them selfs that's down to Indicator stalk so don't no if that is stoping washer working to,,when I press switch for them it is dead no noise coming from pump
xsara Picasso hdi 2.0-------- 2003
Stewart(oily)
- x 35
Re: fuse
I recently had a good result on one of those switch stalks by spraying maintenance spray into the base of the stalk while working the stalk around.
- x 3304
Re: fuse
You might want to try using a proper contact cleaner like these;
http://www.maplin.co.uk/contact-cleaner-25340" onclick="window.open(this.href);return false;
http://www.maplin.co.uk/contact-cleaner-4153" onclick="window.open(this.href);return false;
lasthope1967
Re: fuse
Hell Razor5543 wrote:You might want to try using a proper contact cleaner like this;
I cheers razor i was thinking that me self lol,,got a local maplins down the road thanks
Ben82
- x 7
Re: fuse
This is still quite a bit over my head so someone might be able to read this better than me:
But it looks like F14 in the connection board/fusebox under the bonnet seems related, whether I'm correct or not is another matter
2004 Citroen C5 3L V6 Auto
- x 94
Re: fuse
it would help to see the txt/ component list with that circuit diagram Ben
it might be a good point to start at the pump plug connector to see if any power is getting there
Regards, malcolm.
lasthope1967
Re: fuse
citronut wrote:it would help to see the txt/ component list with that circuit diagram Ben
is it hard to get at,
Ben82
- x 7
Re: fuse
Malcolm: no text with it, but I find this site very useful:
http://peugeot.mainspot.net/wiringall/index.shtml" onclick="window.open(this.href);return false;
Ben82
- x 7
Re: fuse
Possibly not:lasthope1967 wrote:citronut wrote:it would help to see the txt/ component list with that circuit diagram Ben
is it hard to get at,![]()
(click for larger image)But you might be the better judge of that
- x 94
Re: fuse
wow thats very good Ben,
i hate it when you clever techy types add things like those image's,
very impressed
very impressed
Regards, malcolm.
