I have xara Picasso 03 and been told stalk stick for my indicators and lights is faulty because my instrument light panel goes out my lights come on indicators and hazard dont work how much new one and to fit?
mike
stalk stick
Re: stalk stick
I have same prob,but not as bad,,seen a post on here some place were if you drive with side lights on it stops it,,my one only goes off if I turn right or left,,when it goes I get my light icon on dash and horn not work,have alook on ebay for the stalk,
xsara Picasso hdi 2.0-------- 2003
- My Cars: Citroens since 1990, BX Diesel, GTI, TZD with 1.9 TD running extra boost before it was fashionable!, ZX Volcane TD, S2 Xantia break 1.9TD, Xantia HDI 110, currently zipping about in a C2 Diesel. C2 died from the dreaded worm, C3 Picasso HDI Exclusive, the adventure continues.
- x 31
Re: stalk stick
I recently fixed one by spraying maintenance spray into it while moving the stalk about, the auto elecs swore the car needed a fusebox.
Re: stalk stick
just drove from durham to Newcastle and back with side lights on no probs
- Sara Watson's Stalker
- Location: NEW South Wales, Australia. I'll show you "Far, far away" ;-)
- My Cars: Peugeot 605
Citroën Berlingo
Alfa 147 - x 93
The stalk is part of the "Comms" unit. There are a number of variations; it's important to get one that matches your car's control configuration (eg: foglights, rear wipe/wash etc).
To replace is not simple; the battery must be disconnected a good fifteen minutes before any work is done, then you remove the driver's airbag, then the steering wheel, then the comms unit. Pay attention to the new unit, that the tiny little triangles on the centre rotating ring, perfectly align with the fixed arrows. This means the ribbon connector is correctly set to dead ahead.
