Synergie - Ulysse crossover parts.
Johnny Cogs
Unread post by Johnny Cogs »
Hey Folks. With MOT day just around the corner I have a few things I need to fix and a few things I might as well fix at the same time.
I have found a Ulysse at a local breakers (in what looks to be the same colour too) that I was hoping I might be able to pilfer bits from.
Does anyone know if the following are a straight swap?
Heater Blower Motor (3 pin, non aircon)
Rear Wiper Motor
Rear C/L motor
PSGR Sunroof Motor
Front Wings.
Many Thanks :)
'rolls in a 1.9TD Syn-bus!'
x 94
Re: Synergie - Ulysse crossover parts.
Unread post by citronut »
i would have thought if its the same sort of year most of that should interchange,
dont take my word for that though
Regards, malcolm.
Johnny Cogs
Hey Malcolm. I gave the yard a quick call and they were good enough to check the motor connections.... alas, not the type I was looking for... Every blower I have seen so far is of the one plug 4 pin type.... my one in a single plug 3 pin type.... But as it turns out effective window demisting is not part of the VOSA MOT test for private vehicles anyways, so I dont need to panic as much as i was.... As for the rest I will take a pilfering trip up there soon and grab it all anyways...
Richard_C
(Donor 2026)
x 228
Unread post by Richard_C »
I think the lights were different shapes, certainly the tail lights and probably side lights. If you get the front wings you might need the sidelight cluster and indicator repeater as well.
The Synergie, 806 and Useless were mainly distinguished by trim, upholstery and lights. I think the Useless could be ordered with a 3 seat bench for row 3.
If parts are cheap and you have time, it might be worth getting the sliding side door handle assembly. The pin down the middle of the body coloured handle is made of nasty alloy, one of mine has degraded completely. You need to dismantle from the inside of the car.
Don't know about the other bits. The electricals probably depend on who the factory had a delivery from the day before.
Richard_C
