PSA (and Toyota) officially make French cars
x 1425
Unread post by xantia_v6 »
Well you can't get more on-topic than that!
posting a link to another forum, as I don't have time to re-translate:
http://www.france-forum-frenchentree.co ... 9&t=136938" onclick="window.open(this.href);return false;
I wonder if Toyota will be loudly advertising their French credentials?
Do we need a Yaris sub-forum?
addo
Sara Watson's Stalker
x 95
Unread post by addo »
I thought expat forums had been banned worldwide?
x 94
Re: PSA (and Toyota) officially make French cars
Unread post by citronut »
i thought Toyota had a reputation for high slandered's of build quality,
going by a toyota engined 56 plate C1 i worked on a while back were, they seem to be going/gone the same as all other manufacturing industries these days, building crap sub slandered products just to make a quick buck,
this particular car the clutch failed around 30 odd K miles and then the water pump completely fell apart,
Regards, malcolm.
daviemck2006
x 496
Unread post by daviemck2006 »
The clutch and water pump are known weak points of the earlier c1/107/aygo range, later ones, the first facelifted ones from 2009 onwards had an upgraded clutch trom the toyota yaris, 190mm instead of 180mm which are much stronger and retro fitted to earlier models with no mods. My 107 had done over 50k when I sold it and had no issues at all. Was only changed because I needed better seats with more support. AFAIK the engine and box are toyota (japaneese) clutch and water pump valeo (french) The clutches are fine if treated properly, but do not withstand poor driving, slipping the clutch instead of using handbrake and other such bad habits.
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
