Hi all,
Mine is a used C5 II (Facelift), recently I encountered screeching sound when braking. I thought the brake disc(rotor) could have been worn, so I changed it using the brand new Citroen original brake disc a month ago. For the brake pads, I go with brembo. Here is the nightmare, the car will produce sharp screeching sound when brake especially when I need to brake to a stop at traffic light.
Which aftermarket brake pad do you guys use that will not have screeching sound? I would also like to know which brand is the original brake pad in a C5?
Please help and Thank you very much.
Regards,
Choosing the correct Front Brake Pads
SaabC5
Re: Choosing the correct Front Brake Pads
Was copper slip used on the new pads when they were installed?
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
dnsey
- x 19
I believe the calipers are Bosch, so they probably supply the OEM pads too.p
- x 94
Brembo pads are usually ok, or Bendix are another brand that i use
Regards, malcolm.
begins
I wasn’t around to witness the installation hence can’t tell.SaabC5 wrote:Was copper slip used on the new pads when they were installed?
Regards,
begins
I changed to Brembo pads twice and they always give me screeching sound. Now I recalled that I used Bendix for my rear brake and gave no screeching sound.citronut wrote:Brembo pads are usually ok, or Bendix are another brand that i use
Thanks for the pointer and I shall consider Bendix for the next change. Is there a particular Bendix model that you go with?
Regards,
- x 94
that is dependent on your car make/ model and yearbegins wrote: Is there a particular Bendix model that you go with?
Regards,
Regards, malcolm.
- x 2941
Bendix supply a product called 'Bendix brake noise suppressant', it comes in a blue squeeze bottle, coat the back of the pads with it and no more squeals. It should be available through motor factors/pad suppliers.
dnsey
- x 19
Hylomar gasket compound is supposed to be good as a squeal damper too.
