Hi all,
Mine is a used C5 II (Facelift), recently I encountered screeching sound when braking. I thought the brake disc(rotor) could have been worn, so I changed it using the brand new Citroen original brake disc a month ago. For the brake pads, I go with brembo. Here is the nightmare, the car will produce sharp screeching sound when brake especially when I need to brake to a stop at traffic light.
Which aftermarket brake pad do you guys use that will not have screeching sound? I would also like to know which brand is the original brake pad in a C5?
Please help and Thank you very much.
Regards,
Choosing the correct Front Brake Pads
- SaabC5
- My Cars: 09 C5 X7 2.0Hdi Exclusive
Re: Choosing the correct Front Brake Pads
Was copper slip used on the new pads when they were installed?
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
I believe the calipers are Bosch, so they probably supply the OEM pads too.p
Brembo pads are usually ok, or Bendix are another brand that i use
Regards, malcolm.
I wasn’t around to witness the installation hence can’t tell.SaabC5 wrote:Was copper slip used on the new pads when they were installed?
Regards,
I changed to Brembo pads twice and they always give me screeching sound. Now I recalled that I used Bendix for my rear brake and gave no screeching sound.citronut wrote:Brembo pads are usually ok, or Bendix are another brand that i use
Thanks for the pointer and I shall consider Bendix for the next change. Is there a particular Bendix model that you go with?
Regards,
that is dependent on your car make/ model and yearbegins wrote: Is there a particular Bendix model that you go with?
Regards,
Regards, malcolm.
- My Cars: 2006 C5 2.0 Litre HDI VTR Automatic Estate.(now sold on)
Currently Renault Zoe 2014 ZE - x 2508
Bendix supply a product called 'Bendix brake noise suppressant', it comes in a blue squeeze bottle, coat the back of the pads with it and no more squeals. It should be available through motor factors/pad suppliers.
Man is, by nature, a lazy beast, he does not need twice encouraging to do nothing.
Hylomar gasket compound is supposed to be good as a squeal damper too.
