So need to aircon recharged amongst others. Was quoted £49.99 for recharge and £14.99 for antibacteria which now that they mention it I may need cause it's smelly.
Is this a decent price. I've avoided dealers for a few years but I aint going to kwik fit.
Edit: just saw Halfords do bacterial cleanse for 3.99 and 9.99 for charging with their products.
49.99 aircon recharge from.dealer plus £14.99 for antibacter
boristhespie
- x 4
C'est pas possible!
CGATCX25GTITURBO
- x 16
Re: 49.99 aircon recharge from.dealer plus £14.99 for antiba
I have the halfords charge it yourself kit, the car still wasn't as cold as it should be. Maybe because the car hasn't been looked at for a while.boristhespie wrote:So need to aircon recharged amongst others. Was quoted £49.99 for recharge and £14.99 for antibacteria which now that they mention it I may need cause it's smelly.
I haven't seen eye to eye with kwik fit since they told me (my just dealer serviced Berlingo) needs pads and tyres for its MOT, the tyres were 7mm and the pads new
They let me watch the operation and explained what the machine did as it did it during the 40 mins it took. It took and measured the contents on the sytem out, checked for leaks then re filled the oil and refrigerant... result ice cold aircon again
Neil aka CGAT
1986 CX25 GTI TURBO 1 SERIES 2 'CGAT'
1998 XANTIA 19TD ESTATE
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
1989 CX GTI Turbo 62k miles in a barn since 2001, project started 2023.
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
Lighty
- x 35
I charge £40 + vat for a regas, so that price is about right. You cannot do it correctly with a can from Halfords .
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
Xaccers
- x 188
Never had any luck with the cans from Halfrauds.
I usually try to get mine regassed in the winter as most places do it for half price.
Groupon/Living Social/MonsterDeals often have regas vouchers for £14.
DIY sphere tool
DIY sphere tool
- x 1056
Couldn't agree with that more, you could end up doing more damage to the system with those DIY kits as to do it properly you need to vacuum the system to boil off any moisture in there, if you just top it up & the system has moisture in there you will pump it round the whole system. Also you have no idea how much refrigerant is in there to begin with & you may overfill it.Lighty wrote:You cannot do it correctly with a can from Halfords .
Also £50 sounds like a decent price to me.
