can someone help me please
i lost my auxiliary belt driving up the motorway yesterday - managed to get home ok but now need to fit a new one!
BUT seeing as the belt isn't there - I haven't got a reference to how the new one should be fitted!
Can any one help with a routing diagram?
auxiliary belt diagram
- x 8391
Re: auxiliary belt diagram
Welcome to the forum Mr. Davies!
What would help us enormously is to know what car and engine you have
pdavies174
sorry yes its a 2.0hdi xsara picasso 2002
- x 1488
There's a pic in this thread: http://www.frenchcarforum.co.uk/forum/v ... 2&start=15 It's a C5 but the principal is the same, should be type B, ie 3 drives, PAS, Alt, AC comp (unless it's an LX without AC then it will be more like A).
pdavies174
thats brilliant thank you so much
Mandrake
- x 695
Check carefully for any shards of the old belt, they are known to sometimes get under the timing belt cover and cause the timing belt to jump a tooth or two with potentially disastrous results to the engine...it might even be worth taking the timing belt cover off to do a visual inspection, depending on how difficult the access is on that car...
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
addo
- Sara Watson's Stalker
- x 95
Mandrake
- x 695
3000 ??? Or do you mean 300
Simon
1978 CX 2400
1978 CX 2400
- x 8391
Depends entirely upon the last gorilla who tightened it. Most garages seem to have at least one tame gorilla solely for this job...And most believe this bolt should be done up almost to the point of stripping threads.Mandrake wrote:3000 ??? Or do you mean 300
Good thinking to check the crank pulley
Also check the tensioners as well and ensure they are running true to the belt and not at an angle.
Mandrake
- x 695
3000 foot-lb is a typo Jim
Imagine how you would achieve that - 300 lb (50% more than the body weight of even the heaviest amongst us) at the end of a 10 foot long pole!
300 seems high but within the realms of possibility...
Simon
1978 CX 2400
1978 CX 2400
john
like this?pdavies174 wrote:sorry yes its a 2.0hdi xsara picasso 2002
Citroen Xsara Picasso
Subaru Impreza WRX
Nissan Primastar
Subaru Impreza WRX
Nissan Primastar
tonyfay
- x 3
Hi ,
Im hoping someone can help .
i urgently ( Going to my Daughters wedding tomorrow) need to replace a broken auxiliary drive belt on my Xsara Picasso 2007 1.6 16v petrol with AC.
I have obtained the correct replacement belt.,
But I am looking for a diagram of the belt positioning details for the pulleys and tensioner.
Kind regards,
Tony
Kind regards,
Tony
Steve Walsh
- x 518
I have no info on that one, but the back of the belt will run on the smooth pulleys, should be able to figure it out
tonyfay
- x 3
Thanks Steve for your time and reply,
I have had a look but not quite sure. I have the back of the belt on the tensioner smooth pulley, just not clear on where I go from there. I have searched the web to no avail .
tonyfay
- x 3
Ok Steve,
I have figured it out , it was the second smooth idler pulley that confused me,
But got there in the end.
thanks for the tip,
Tony
thanks for the tip,
Tony
