auxiliary belt diagram
pdavies174
Unread post by pdavies174 »
can someone help me please
i lost my auxiliary belt driving up the motorway yesterday - managed to get home ok but now need to fit a new one!
BUT seeing as the belt isn't there - I haven't got a reference to how the new one should be fitted!
Can any one help with a routing diagram?
x 8400
Re: auxiliary belt diagram
Welcome to the forum Mr. Davies!
What would help us enormously is to know what car and engine you have :)
pdavies174
sorry yes its a 2.0hdi xsara picasso 2002
x 1489
There's a pic in this thread: http://www.frenchcarforum.co.uk/forum/v ... 2&start=15 It's a C5 but the principal is the same, should be type B, ie 3 drives, PAS, Alt, AC comp (unless it's an LX without AC then it will be more like A).
pdavies174
thats brilliant thank you so much
x 695
Unread post by Mandrake »
Check carefully for any shards of the old belt, they are known to sometimes get under the timing belt cover and cause the timing belt to jump a tooth or two with potentially disastrous results to the engine...it might even be worth taking the timing belt cover off to do a visual inspection, depending on how difficult the access is on that car...
addo
Sara Watson's Stalker
x 95
Unread post by addo »
The damper pulley - which you need to remove to take off the lower timing cover - is bolted on with about 3,000 foot-pounds of torque.
For that matter, a good time to check the damper pulley in case it caused the belt to be thrown.
x 695
3000 ??? Or do you mean 300 :lol:
x 8400
Mandrake wrote:3000 ??? Or do you mean 300 :lol:
Depends entirely upon the last gorilla who tightened it. Most garages seem to have at least one tame gorilla solely for this job...And most believe this bolt should be done up almost to the point of stripping threads.
Good thinking to check the crank pulley :)
Also check the tensioners as well and ensure they are running true to the belt and not at an angle.
x 695
3000 foot-lb is a typo Jim :lol:
Imagine how you would achieve that - 300 lb (50% more than the body weight of even the heaviest amongst us) at the end of a 10 foot long pole! :shock: :-D
300 seems high but within the realms of possibility...
john
Unread post by john »
pdavies174 wrote:sorry yes its a 2.0hdi xsara picasso 2002
like this?
Citroen Xsara Picasso
Subaru Impreza WRX
Nissan Primastar
tonyfay
x 3
Unread post by tonyfay »
Hi ,
Im hoping someone can help .
i urgently ( Going to my Daughters wedding tomorrow) need to replace a broken auxiliary drive belt on my Xsara Picasso 2007 1.6 16v petrol with AC.
I have obtained the correct replacement belt.,
But I am looking for a diagram of the belt positioning details for the pulleys and tensioner.
Kind regards,
Tony
Steve Walsh
x 518
Unread post by Steve Walsh »
I have no info on that one, but the back of the belt will run on the smooth pulleys, should be able to figure it out
tonyfay
x 3
Thanks Steve for your time and reply,
I have had a look but not quite sure. I have the back of the belt on the tensioner smooth pulley, just not clear on where I go from there. I have searched the web to no avail .
tonyfay
x 3
Ok Steve,
I have figured it out , it was the second smooth idler pulley that confused me,
But got there in the end.
thanks for the tip,
Tony
