Dont want to break it just yet!
Cheers, Mark
That is exactly what is use, 9000 for non DPF and ECS for with DPF.411514 wrote:Assuming it does not have a DPF, which I dont think it has then Total Quartz 9000 5W-40, is I believe the stuff recommended by citroen. I use it in my c5 with the same engine (8v?). If you do have a DPF then in theory you need a low saps oil, like Total ecs 5W-30, Sam
= "These oils do not use in the following vehicles: Xsara VTS 2.0i 16V, jumper 2.8TDI, 2.8HDI, 2.0 and 2.2HDi engines with particulate filters"German wrote:(*) Diese Ole bei folgenden Fahrzeugen nicht verwenden: Xsara Coupe VTS 2.0i 16V, Jumper 2.8TDI, 2.8HDi, Motoren 2.0 und 2.2HDi mit Partikelfilter
