Which engine oil?
MonkeyMark
Which engine oil?
Unread post by MonkeyMark »
Silly question, but which engine oil should i use on a C8 2.0Hdi (2003)? It has about 80k miles if that makes a difference.
Dont want to break it just yet! :-D
Cheers, Mark
Happy(ish) C8 owner.
411514
(Donor 2017)
x 40
Re: Which engine oil?
Unread post by 411514 »
Assuming it does not have a DPF, which I dont think it has then Total Quartz 9000 5W-40, is I believe the stuff recommended by citroen. I use it in my c5 with the same engine (8v?). If you do have a DPF then in theory you need a low saps oil, like Total ecs 5W-30, Sam
Sam
2003 C5 2.0HDI 110
Citroenmad
x 110
Unread post by Citroenmad »
411514 wrote:Assuming it does not have a DPF, which I dont think it has then Total Quartz 9000 5W-40, is I believe the stuff recommended by citroen. I use it in my c5 with the same engine (8v?). If you do have a DPF then in theory you need a low saps oil, like Total ecs 5W-30, Sam
That is exactly what is use, 9000 for non DPF and ECS for with DPF.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
Ben82
x 7
Unread post by Ben82 »
Odd, my Service Manual (albeit is in German), but states that the 5W-30 is NOT for HDis with particle filter.
German wrote:(*) Diese Ole bei folgenden Fahrzeugen nicht verwenden: Xsara Coupe VTS 2.0i 16V, Jumper 2.8TDI, 2.8HDi, Motoren 2.0 und 2.2HDi mit Partikelfilter
= "These oils do not use in the following vehicles: Xsara VTS 2.0i 16V, jumper 2.8TDI, 2.8HDI, 2.0 and 2.2HDi engines with particulate filters"
2004 Citroen C5 3L V6 Auto
Citroenmad
x 110
Is that for the Total ECS oil Ben82?
If I remember correctly the Total ECS was designed for Peugeot/Citroen engines with DPF's ...
Interestingly my local Citroen dealers only stock the very basic Total oil and that is all they put in every car on a service. Hmm, I did try and correct them but I left thinking that I know more than they do :lol:
Too expensive to use the ECS oil apparently ... :shock:
03 Seat Arosa 1.0S
Ben82
x 7
Don't think so actually.. it's Quartz Futur 9000 5W-30 and Quartz Futur Diesel 9000 5W-30 (guessing they mean Future)
They don't list any others, but both are the only 5W-30 ones they list. :)
MonkeyMark
Thanks for the help. Not sure if it has a dpf but think it may be the 16 valve engine.
What's the best way to check?
x 1485
To check for DPF have a look underneath at the exhaust - if it's got a large cat with pipes going to it, it's got a DPF. Alternatively post up the last 8 digits of your VIN and we can check on service.citroen.
Handbook for our C4GP says ECS oil OK for DPF - it says not to use Activa energy 9000 or Quartz Energy 9000 in DPF engines. Says you can use 5W/30, 5W/40 or 10W/40 in the 1.6 HDi, depending on operating temp range.
x 3566
You can check on the Total website for their version of the correct oil for your car.....
http://total-gbr.lubricantadvisor.com/" onclick="window.open(this.href);return false;
