fitting pads front and rear c5 2.2 hdi 2003
bill196510
Is there anything I should know, also track rods and drop links
C5 2.2 hdi 2003, called it oliver reed, drinks like him
Good on fuel now, lol.
bill196510
Re: fitting pads front and rear c5 2.2 hdi 2003
Drivers side piston wont wind in, using tool that fits on ratchet, winds out easy, winds in a little bit then just keeps turning,
Not tried other side yet
- x 1240
You may need to apply a bit of pressure as you rotate it.
dnsey
- x 19
How are the rear calipers?
You may be aware of the problem with corrosion forcing them out of place. It can be a bit awkward removing the retaining bolts to rectify this, but it's do-able with patience, care and decent tools.
Monkeyfeet
Like PeterN said, bit of pressure should do it. Also don't the fronts wind-in in different directions?
XantiaTD's(all gone). BXGTi, sold (sob). C5 2.2Hdi SE Exc Hatch. C5 2.2 Estate auto. Xsara Hdi estate. Yam YZF750, Zoom. GSX-S750, mmm.
waynedance
- x 8
Maybe a silly question but have you removed cap from brake fluid bottle??
Volvo S80 D5.........
bill196510
not silly when it involves me ;-(waynedance wrote:Maybe a silly question but have you removed cap from brake fluid bottle??
didnt remove cap.lol.
removed it and with alot of effort piston went in
thats one side ok,now for drop links bolts just spin
and no alan key hole in end,lol.
waynedance
- x 8
bill196510 wrote:not silly when it involves me ;-(waynedance wrote:Maybe a silly question but have you removed cap from brake fluid bottle??
I asked as I was in doing the same the other week and piston would not wind in on my dads Scenic but realized after 5 mins I had not removed the cap, so much easier after removing.
Monkeyfeet
Another little trick can be to loosen the bleed screw, so the fluid comes out instead of being pushed back up the brake lines. Fiddly to make sure that air doesn't get in but does work. Stops fluid being pushed back through the ABS block too.
- x 5673
Far about £1 most motor factors and car spares shops will have a rubber pipe with a non return valve in it to fit over the nipple that prevents any air ingress.Monkeyfeet wrote:Another little trick can be to loosen the bleed screw, so the fluid comes out instead of being pushed back up the brake lines. Fiddly to make sure that air doesn't get in but does work. Stops fluid being pushed back through the ABS block too.
bill196510
ill get one of thosemyglaren wrote:Far about £1 most motor factors and car spares shops will have a rubber pipe with a non return valve in it to fit over the nipple that prevents any air ingress.Monkeyfeet wrote:Another little trick can be to loosen the bleed screw, so the fluid comes out instead of being pushed back up the brake lines. Fiddly to make sure that air doesn't get in but does work. Stops fluid being pushed back through the ABS block too.
