fitting pads front and rear c5 2.2 hdi 2003
bill196510
Unread post by bill196510 »
Is there anything I should know, also track rods and drop links
C5 2.2 hdi 2003, called it oliver reed, drinks like him :(
Good on fuel now, lol.
bill196510
Re: fitting pads front and rear c5 2.2 hdi 2003
Drivers side piston wont wind in, using tool that fits on ratchet, winds out easy, winds in a little bit then just keeps turning,
Not tried other side yet
x 1240
Unread post by Peter.N. »
You may need to apply a bit of pressure as you rotate it.
dnsey
x 19
Unread post by dnsey »
How are the rear calipers?
You may be aware of the problem with corrosion forcing them out of place. It can be a bit awkward removing the retaining bolts to rectify this, but it's do-able with patience, care and decent tools.
Monkeyfeet
(Donor 2022)
Unread post by Monkeyfeet »
Like PeterN said, bit of pressure should do it. Also don't the fronts wind-in in different directions?
XantiaTD's(all gone). BXGTi, sold (sob). C5 2.2Hdi SE Exc Hatch. C5 2.2 Estate auto. Xsara Hdi estate. Yam YZF750, Zoom. GSX-S750, mmm.
waynedance
x 8
Unread post by waynedance »
Maybe a silly question but have you removed cap from brake fluid bottle??
Volvo S80 D5.........
C5 2.2HDi Exclusive 2003 manual (now gone).
2009 Renault Megane, the misses drive.
Had a 1988 BX 19TRS Auto many moons ago.
Forgive any spelling mistakes, it's the phone not me.
bill196510
waynedance wrote:Maybe a silly question but have you removed cap from brake fluid bottle??
not silly when it involves me ;-(
didnt remove cap.lol.
removed it and with alot of effort piston went in ;-)
thats one side ok,now for drop links bolts just spin
and no alan key hole in end,lol.
waynedance
x 8
I asked as I was in doing the same the other week and piston would not wind in on my dads Scenic but realized after 5 mins I had not removed the cap, so much easier after removing.
Monkeyfeet
(Donor 2022)
Another little trick can be to loosen the bleed screw, so the fluid comes out instead of being pushed back up the brake lines. Fiddly to make sure that air doesn't get in but does work. Stops fluid being pushed back through the ABS block too.
x 5634
Monkeyfeet wrote:Another little trick can be to loosen the bleed screw, so the fluid comes out instead of being pushed back up the brake lines. Fiddly to make sure that air doesn't get in but does work. Stops fluid being pushed back through the ABS block too.
Far about £1 most motor factors and car spares shops will have a rubber pipe with a non return valve in it to fit over the nipple that prevents any air ingress.
bill196510
ill get one of those :-)
