PD Engine
wigelywoo
PD Engine
Unread post by wigelywoo »
Is the 1.6 hdi engine (110bhp) one of the engines that require a special oil, or will any 5/40 do.
Many thanks
There are two secrets to success
1. never reveal all you know
spider
x 77
Re: PD Engine
Unread post by spider »
I'm not sure on the grade (no doubt someone else will answer shortly) although I'd say semi synth at a minimum, certainly not plain mineral oil.
The biggest concern with these units is the frequency of the changes, they should be done more often than officially recommended. Personally I think 10K, never mind anything higher is stretching oil a bit far especially given a diesel engine is quite prone to sludge formation anyway.
Andy.
Bick
x 43
Re: PD Engine
Unread post by Bick »
the HDI is not a PD engine but it does require fully synthetic oil.
Citroen now recommend 5/30 although you can used 5/40 if you do not have a particulate filter
check for comma recommendations here http://www.commaoil.com/products/" onclick="window.open(this.href);return false;
Richard Stevens
Re: PD Engine
Unread post by Richard Stevens »
I know there is a lot of hype about engine oil, but the oil that I am told to use for this engine is Total INEO ECS C2.
This took me quite a while to find out, but I have since had confirmation from many sources.
Best price is on eBay, I think.
RS
1995 ZX Turbo diesel Volcane
1999 Xantia HDI
2005 C5 1.6 HDI
2006 C5 2.0 HDI Exclusive
Remember - many warnings are spurious or bad connections
x 1496
Re: PD Engine
The handbook is pretty vague about the oil spec - you can use a variety of viscosities depending on the temperature. What IS important for the HDi is to use a low ash / SAPs oil to prolong the life of the DPF - and tighten up the injector bolts as referred to in a few threads here.
