Excuse the V6 newbie questions.
The stop light and coolant temperature lights flash when the coolant is a 80 level. I looked at the header tank to measure the coolant and this appears to be normal (any advice on what normal looks like as on all the other TD's I have had there is a level indicator?)
On checking the old receipts for the car I note that the header tank has been replaced under 5k ago.
Engine fans are kicking in fine.
Any suggestions on what could cause this? I assume at that temperature its safe to keep it running?
