V6Xantia stop light and coolant temperature lights flashing.
magictorch
Unread post by magictorch »
Having now taken the V6 off the market and using her as a daily car again I encountered an odd fault with it today. On researching the forum i note that others have had similar issues.
Excuse the V6 newbie questions. :oops:
The stop light and coolant temperature lights flash when the coolant is a 80 level. I looked at the header tank to measure the coolant and this appears to be normal (any advice on what normal looks like as on all the other TD's I have had there is a level indicator?)
On checking the old receipts for the car I note that the header tank has been replaced under 5k ago.
Engine fans are kicking in fine.
Any suggestions on what could cause this? I assume at that temperature its safe to keep it running?
x 1459
Re: V6Xantia stop light and coolant temperature lights flash
Unread post by xantia_v6 »
The most likely cause is a faulty Bitron sensor. This is the brown sensor near the thermostat.
magictorch
Yes I have seen that mentioned before,plus a whole discussion on how 'difficult' it is to change. I think it is a sensor fault, as the light does come on when I floor it :-D
x 1459
They are not really difficult to change, the last one I did took about 10 minutes. The difficulty varies a bit depending on the angle of the spring clip on the connector. Once the connector is off, changing the sensor is easy with a suitable deep socket, I don't even drain the coolant, just pop the new one in quickly.
magictorch
Where did you source the sensor?
x 1459
The same sensor was used on most PSA vehicles (with Air Conditioning) from the mid 90s, so it is a common part.
They are usually available on ebay, but most there are reproductions (I have always managed to find a genuine part eventually). I don't think they are very expensive from the dealer.
allanmc
Unread post by allanmc »
I have a series 2 Xantia 2lt.HDI and when I put the heater control to demist the stop light and temp light flashes, but the other day when I moved the control to demist the dash board lights dimmed for a second as the heater fan came on never noticed this before
allanmc
Xantia 2.0i SX Auto, 1999
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
allanmc wrote:I have a series 2 Xantia 2lt.HDI and when I put the heater control to demist the stop light and temp light flashes
Check that both cooling fans are running when the A/C is turned on (putting heater control to demist does that), had that happen on one of Xantia HDi's.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
allanmc
Car running heater on demist stoplight flashed for a few times then stopped, left car running till it reached normal temp. still fans didnt come on, I know there is plenty of coolant and its not over heating I think I will just live with it along with the other faults that Ive had for a long time, but thanks for your input
