When I push the steering wheel up and down in my Xantia I can feel that it rattles a bit in the steering wheel column. Looking at Citroen service I cannot find any bush (as it was in the BX ) . Is it a way to eliminate this ?
Zohar
Xantia - Steering wheel rattles a bit inside steering column
- My Cars: Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD - x 8
Re: Xantia - Steering wheel rattles a bit inside steering co
Any idea ?
Zohar
Zohar
- My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars. - x 1207
Worn universal joint on the column most likely.
Can this be repaired ?
Zohar
Zohar
It can be replaced but if its done a lot of miles some wear is acceptable, if it rattles while you are driving, getting some grease into it may quieten it down.
Does this mean replacing the whole steering wheel column ?
Zohar
Zohar
- Old-Guy
- My Cars: 2011 Grand C4 Picasso VTR+ 1.6HDi in Kyanos Blue
1995 Xantia Estate SX 1.9TD in Vert Vega "The Green Lady" - now owned by XanTom
1998 Xantia 2.1 VXD Estate in Mauritius Blue - R.I.P. (terminal tin-worm) - x 17
Depends what you mean by "up and down". Movement along the axis of the steering column will be wear in the UJ. Movement at right angles is play in the top bearing - some is normal even on fairly low mileage Xantias. I don't think there is a replaceable bush in the Xantia.
1995 Xantia Estate SX 1.9TD in Vert Vega "The Green Lady" - after 11 years now owned by XanTom
- CitroJim
- x 6204
- Contact:
There isn't The bearing, such as it is, is built into the outer casing of the column and is not a replaceable item. best to source a good column with a good bearing in it...Old-Guy wrote: I don't think there is a replaceable bush in the Xantia.
I'm sure, once this becomes a real problem, a workaround will be found... Have lathe, will make one...
Too much play, in the eyes of an MOT tester, is a fail. I've known a Pug 306 (which uses an essentially similar column) fail for just this reason.
