When I push the steering wheel up and down in my Xantia I can feel that it rattles a bit in the steering wheel column. Looking at Citroen service I cannot find any bush (as it was in the BX ) . Is it a way to eliminate this ?
Zohar
Xantia - Steering wheel rattles a bit inside steering column
lancia58
- x 8
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
lancia58
- x 8
Re: Xantia - Steering wheel rattles a bit inside steering co
Any idea ?
Zohar
Zohar
- x 1240
Worn universal joint on the column most likely.
lancia58
- x 8
Can this be repaired ?
Zohar
Zohar
- x 1240
It can be replaced but if its done a lot of miles some wear is acceptable, if it rattles while you are driving, getting some grease into it may quieten it down.
lancia58
- x 8
Does this mean replacing the whole steering wheel column ?
Zohar
Zohar
Old-Guy
- x 26
Depends what you mean by "up and down". Movement along the axis of the steering column will be wear in the UJ. Movement at right angles is play in the top bearing - some is normal even on fairly low mileage Xantias. I don't think there is a replaceable bush in the Xantia.
- x 8406
There isn'tOld-Guy wrote: I don't think there is a replaceable bush in the Xantia.
I'm sure, once this becomes a real problem, a workaround will be found... Have lathe, will make one...
Too much play, in the eyes of an MOT tester, is a fail. I've known a Pug 306 (which uses an essentially similar column) fail for just this reason.
