C5 2002 questions
C5 2002 questions
Hi people.
Can anyone answer these questions for me.
I have a Citroen C5 Exclusive 16V Auto (2.0l Petrol), 2002 reg.
1) Is there anyway to "dumb down" the automatic wipers or even bin them for a standard intermittent setting? I am getting sick of it going to full on - worse double speed when all I want is intermittent or normal speed. The automatic wipers seem like a good idea, just poorly implemented.
2) MY heater is great when I put it on 28c, gets nice a toasty. But when I turn it down to 27c it is like opening a fridge door. I used to sit my old Primera at 26c on low fans and be nice and comfy in the winter months.
3) I have not had a petrol car since 1997, is it worth putting in stuff like RedX or anything else to help the fuel economy these days or does it just come down to sensible driving to try and eek out what I can. I know I won't get hte 40+mpg I got driving a diesel but I want to get the best I can, and also being an automatic I am trying not to drive with a lead foot and late braking (as I have no clutch to dip now ).
MAx
MAx
2008 RENAULT LAGUNA 3 EXPRESSION DCI 130 - Satnav, Bluetooth and more...
- My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars. - x 1204
Re: C5 2002 questions
Hi Max
Can't help you with the wipers I'm afraid but your heater problem may be due to a faulty external temperature sensor, what is the display reading, If its showing a much higher temperature than it actually is the sensor wants replacing, its in the bottom of the passenger side mirror.
I haven't run a petrol car for about 30 years so can't help you there either, the only thing I will say is that my 2.0. Hdi C5 will do over 60 mpg driven gently don't get a 2.2 though they are dreadful on fuel.
- Ben82
- My Cars: C5 V6 2004
- x 7
1) There are options in the lexia to change the wipers, I wasn't brave enough at the time to have a fiddle around with them. Good to see someone with similar issues.... mine seems to be they don't go on when it's raining and I have to do it myself, or if they do turn on, and the rain eases off they keep going.
2) Not had this on mine, find it funny that you have also came from a Primera mine was a 03 reg 2.2 Diesel, lovely car, shame I had to leave it in the UK. Never quite put it up to 26C think 24 was my max.
2004 Citroen C5 3L V6 Auto
Brit living in Sweden with an imported from Germany French Car!
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3007
You might want to make sure the windscreen is spotlessly clean where the rain sensor is (usually on the mirror mount). If this is dirty the sensor will get a refection, and will trigger the wipers (as it thinks the screen is wet).
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Hi Peter. The outside sensor is knackered. It was saying 48c when it was really -5 last week!!! If I need a replacement I will ask the local scrap yard and see if they have a C5 in that I can steal the sensor off as I need a couple of other bits as well.Peter.N. wrote:Hi Max
Mine was a 2004 2.2Dci SE. Loved it until part of the engine decided to go see the outside world and killed the car (outside a cemetery of all places ).Ben82 wrote:1) There are options in the lexia to change the wipers, I wasn't brave enough at the time to have a fiddle around with them. Good to see someone with similar issues.... mine seems to be they don't go on when it's raining and I have to do it myself, or if they do turn on, and the rain eases off they keep going.
The wipes are driving me insane, I may have a word with my local garage who have access to a Lexia next time I need something doing and see if they can "correct" the problem if nothing else can fix it....
turn the auto wipe off and d just use as standard wipers. i have a problem with mine but i think it may be down to the comm 2000 unit being on its way out
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
Hi Max
You can use a scondhand one but get it from as late a vehicle as possible because they don't last long. I think most Citroens and Peugeots use the same one, I know the XM is the same. They are about £30.00 form Citroen.
Good idea bar there being no intermittent setting I can use which is why I have to put it on Auto at times to get something which can somewhat pass for one.oneday wrote:turn the auto wipe off and d just use as standard wipers. i have a problem with mine but i think it may be down to the comm 2000 unit being on its way out
Max
you may have the same problem as me with the com 2000 unit. i just use the single wipe on mine when the auto wipe throws a wobler
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
- My Cars: 2010 Citroen C5 3.0 V6 Exclusive + Navi
2009 Citroen C6 2.7 V6 Exclusive + Lounge Pack
2007 Citroen C5 2.2 (173) Exclusive + Navi
2000 Citroen Xantia Activa - x 17
I am convinced there must be somthing wrong with your wipers because i would not be without the auto wipers i love them.
Mine did too until I replaced the passenger's side wiper blade.The wipers are driving me insane
It didn't wipe the rain sensor properly.
It's easiest to work on the wipers when they're stopped pointing upwards.
To park the wipers vertically, take the key out after stopping the engine, then within 30 seconds push the wiper stalk down once.
2002 C5 2.0i AL4 230,000 km 76372389
Thanks for the ideas. I will take a look at the wiper blades and sensor area at the weekend and see what I can see.
Max
Max
