Hello,
I wonder if anyone has any ideas about this problem ! My 1999 2.0 HDi Xantia has recently started over reading on the rev counter by 1000rpm.
It all started when the instruments decided to flip over when strting despite having a new battery. The rev counter now sits at 0 against the needle when the ignition is off but as soon as I turn on the ignition it sets itself at the 1000rpm position and ticks over indicating 2100rpm....
Suggestions please !!!!
Thanks.
Xantia rev counter over reading !
- x 1240
Re: Xantia rev counter over reading !
Possibly a poor connection somewhere which is arcing and generating a spurious signal.
- x 8441
I've seen this once before on an S2 Xantia and was replaced by replacing the instrument pod. Rather a sledgehammer approach.
S2 Xantia instruments are all electronic and connect to the printed circuit board containing their 'works' via spring 'fingers'. These are notorious for making bad connections and affecting how the gauges read.
The good news is that with a bit of care the instrument pod will come apart - just watch the ribbon cable going to the LCD mileage counter - and that will enable the fingers and their respective pads to be cleaned.
Here's some pictures:
