what would have happern if i had normal suspesion ?
jacksun1987
I got up for work normal day. Started driving noticed this thumping niose. Must have drove 5 miles it was getting loader. I stopped i did the back right side tryer was on the rim with holes in it. I didnt have my fone on me.. I drove back home this tyers with holes in it on the rim. Took me ages was going between 5 and 10 mph. Surly some kids deflated it or somthing. Surly a tryer doesnt go down over nite with no reason?
Mandrake
- x 695
Re: what would have happern if i had normal suspesion ?
There will be a nail or something similar in it - usually when I've had an overnight leak its been a nail, or on one occasion a sharp sliver of stone/concrete that stabbed through the tread of the tyre like a spear
Because it blocks the hole it makes (assuming it stays in) the leak is very slow and may take all night to go down.
I bet you will find something like a nail or piece of glass buried in the tread if you look hard enough. (unless it was actually kids having a laugh)
PS did you not have a spare tyre ? Not sure that I would have been happy driving back home 10 miles on the rim, fancy suspension or not... And would you get pulled over for it if caught ? I'm not sure that "sorry officer, I didn't notice it" would have held water
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
- x 1240
I drove a CX Safari for several miles on the newly built M5 some years ago, with a flat front o/s tyre, I thought the ride was a bit rough but the car handled fine, but that was a much better suspension/steering system than any modern cars have.
citroenxm
- Fallen Hero
- x 70
Same here with my XM V6 SEi, was driving striaight as a Die, then when I came to a junction, thats when I felt the issue.. and had to change the tyre there and then!Peter.N. wrote:I drove a CX Safari for several miles on the newly built M5 some years ago, with a flat front o/s tyre, I thought the ride was a bit rough but the car handled fine, but that was a much better suspension/steering system than any modern cars have.
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 3298
This is the advantage (and dis-advantage) of the hydro-pneumatic suspension. I remember hearing that, not long after its' launch, a DS was entered into the Paris-Dakkar rally. During one of the stages the OSR wheel got removed by a large object (but the brake disc was left attached). Despite this slight problem the car managed to make to to the next service point, where a new trailing arm was fitted.
Homer
- x 16
You drove 10 miles on a completely flat tyre? No way, the tyre would have disintegrated long before leaving you with a badly damaged wheel rim.
And knowing you had a flat you drove 5 miles back? Pretty stupid thing to do no matter what speed. You don't have a spare or breakdown cover? You say didn't have you phone but there are still such things as public telephones.
Citroenmad
- x 110
That was quite lucky!
Its a little different to a blow out at speed, as a sudden deflation upsets the balance and the sudden drag from the flat tyre will upset things further. Driving from rest on a flat should have been noticeable too, if it was right down on the rim. The ride quality of a Citroen and the stability it provides can mask such things slightly, which is why they have a few mentions of driving with flat tyres in their past.
It is an offence to drive with underinflated tyres, driving with a flat tyre (known about or not, as you really should) would not be an easy thing to get off with.
Of course, keep driving on a flat tyre and it will soon wear the sidewall very thin and you risk it coming off on a corner. Or the sidewall will wear right through and the tyre will come off that way. At speed, that is very alarming and with speed comes heat, which makes a flat tyre wear out over quickly. Even a soft tyre will wear out quickly at speed.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
Northern_Mike
I have no idea how long the tyre on my Xantia lasted when I had a blow out at 90. Probably more than 5 miles. I'd been smelling a slight burning smell for some time before I pulled into the motorway services to investigate. Tyre was completely flat but hadn't disintegrated at all. Smelt a bit. Handling was unaffected until I got into the services and had to turn sharply.Homer wrote:You drove 10 miles on a completely flat tyre? No way, the tyre would have disintegrated long before leaving you with a badly damaged wheel rim..
Northern_Mike
Rust inside the wheel rims leading to them not sealing and the tyre going down overnight. This happened to me on RUNN, the white Xantia TD I had in the summer, on both rears within a week of each other. Each time the tyre place inflated them and showed me exactly where they were leaking at the rim. A good wire brushing seems to have cured them as they haven't gone down since.jacksun1987 wrote:I got up for work normal day. Started driving noticed this thumping niose. Must have drove 5 miles it was getting loader. I stopped i did the back right side tryer was on the rim with holes in it. I didnt have my fone on me.. I drove back home this tyers with holes in it on the rim. Took me ages was going between 5 and 10 mph. Surly some kids deflated it or somthing. Surly a tryer doesnt go down over nite with no reason?
jacksun1987
got the spear on now so need to get another wheel tryer from somwhere
