what would have happern if i had normal suspesion ?
jacksun1987
Unread post by jacksun1987 »
I got up for work normal day. Started driving noticed this thumping niose. Must have drove 5 miles it was getting loader. I stopped i did the back right side tryer was on the rim with holes in it. I didnt have my fone on me.. I drove back home this tyers with holes in it on the rim. Took me ages was going between 5 and 10 mph. Surly some kids deflated it or somthing. Surly a tryer doesnt go down over nite with no reason?
x 695
Re: what would have happern if i had normal suspesion ?
Unread post by Mandrake »
There will be a nail or something similar in it - usually when I've had an overnight leak its been a nail, or on one occasion a sharp sliver of stone/concrete that stabbed through the tread of the tyre like a spear :shock: Because it blocks the hole it makes (assuming it stays in) the leak is very slow and may take all night to go down.
I bet you will find something like a nail or piece of glass buried in the tread if you look hard enough. (unless it was actually kids having a laugh)
PS did you not have a spare tyre ? Not sure that I would have been happy driving back home 10 miles on the rim, fancy suspension or not... And would you get pulled over for it if caught ? I'm not sure that "sorry officer, I didn't notice it" would have held water :lol:
x 1240
Unread post by Peter.N. »
I drove a CX Safari for several miles on the newly built M5 some years ago, with a flat front o/s tyre, I thought the ride was a bit rough but the car handled fine, but that was a much better suspension/steering system than any modern cars have.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Peter.N. wrote:I drove a CX Safari for several miles on the newly built M5 some years ago, with a flat front o/s tyre, I thought the ride was a bit rough but the car handled fine, but that was a much better suspension/steering system than any modern cars have.
Same here with my XM V6 SEi, was driving striaight as a Die, then when I came to a junction, thats when I felt the issue.. and had to change the tyre there and then!
A very sad...
1994 XM 2.1 d auto
x 3298
This is the advantage (and dis-advantage) of the hydro-pneumatic suspension. I remember hearing that, not long after its' launch, a DS was entered into the Paris-Dakkar rally. During one of the stages the OSR wheel got removed by a large object (but the brake disc was left attached). Despite this slight problem the car managed to make to to the next service point, where a new trailing arm was fitted.
Homer
x 16
Unread post by Homer »
You drove 10 miles on a completely flat tyre? No way, the tyre would have disintegrated long before leaving you with a badly damaged wheel rim.
And knowing you had a flat you drove 5 miles back? Pretty stupid thing to do no matter what speed. You don't have a spare or breakdown cover? You say didn't have you phone but there are still such things as public telephones.
Citroenmad
x 110
Unread post by Citroenmad »
That was quite lucky!
Its a little different to a blow out at speed, as a sudden deflation upsets the balance and the sudden drag from the flat tyre will upset things further. Driving from rest on a flat should have been noticeable too, if it was right down on the rim. The ride quality of a Citroen and the stability it provides can mask such things slightly, which is why they have a few mentions of driving with flat tyres in their past.
It is an offence to drive with underinflated tyres, driving with a flat tyre (known about or not, as you really should) would not be an easy thing to get off with.
Of course, keep driving on a flat tyre and it will soon wear the sidewall very thin and you risk it coming off on a corner. Or the sidewall will wear right through and the tyre will come off that way. At speed, that is very alarming and with speed comes heat, which makes a flat tyre wear out over quickly. Even a soft tyre will wear out quickly at speed.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
Northern_Mike
Homer wrote:You drove 10 miles on a completely flat tyre? No way, the tyre would have disintegrated long before leaving you with a badly damaged wheel rim..
I have no idea how long the tyre on my Xantia lasted when I had a blow out at 90. Probably more than 5 miles. I'd been smelling a slight burning smell for some time before I pulled into the motorway services to investigate. Tyre was completely flat but hadn't disintegrated at all. Smelt a bit. Handling was unaffected until I got into the services and had to turn sharply.
Northern_Mike
jacksun1987 wrote:I got up for work normal day. Started driving noticed this thumping niose. Must have drove 5 miles it was getting loader. I stopped i did the back right side tryer was on the rim with holes in it. I didnt have my fone on me.. I drove back home this tyers with holes in it on the rim. Took me ages was going between 5 and 10 mph. Surly some kids deflated it or somthing. Surly a tryer doesnt go down over nite with no reason?
Rust inside the wheel rims leading to them not sealing and the tyre going down overnight. This happened to me on RUNN, the white Xantia TD I had in the summer, on both rears within a week of each other. Each time the tyre place inflated them and showed me exactly where they were leaking at the rim. A good wire brushing seems to have cured them as they haven't gone down since.
jacksun1987
got the spear on now so need to get another wheel tryer from somwhere
