i believe my 1.4 hdi 307 has lost its immobiliser coding
mozzy
Unread post by mozzy »
basically bought the car, it turns over but wont fire, if i spray a bit of easy start in, it starts to fire but wont actually run, there is a little red light on the lock button on centre dash flashing frantically constantly.
any ideas
x 94
Re: i believe my 1.4 hdi 307 has lost its immobiliser coding
Unread post by citronut »
you need to get it hooked up to a LEXIA look at the map in the link below for the neaest member to you that owns one
http://www.frenchcarforum.co.uk/forum/v ... 19&t=29178" onclick="window.open(this.href);return false;
Regards, malcolm.
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
Have you tried using another key in case the chip in the first key is broken?
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
mozzy
i only have the 1 key, im getting a bit paranoid as i have done a google search and this seems to be a common fault when they have been jump started, something about the bsi packing up and needing a new one.....can lexia sort this
The Birdman
Unread post by The Birdman »
Lexia is for citroen , you`re looking for PP2000/Diagbox , although they all run of same hardware ,
the car is only burning the easy start but at least its turning over , first port of call would be recode the keys , Pug are renowned for losing the keycodes because of weak battery`s , i take it you jump started it because of a weak battery ?
For what we are about to receive may we be truly thank full.
http://www.citroencodes.com" onclick="window.open(this.href);return false;
http://www.peugeotcodes.com" onclick="window.open(this.href);return false;
407iain
Unread post by 407iain »
Depending where you are another member could plug it in.
I have pp2k/lexia.
Sent from my HTC Wildfire using Tapatalk 2
2011 RCZ THP 200 GT
mozzy
im in Glastonbury...... the girl i got it from had her dad try starting it from a jump pack, i just put a good 700 cranking amp battery on it , the most annoying bit is i am a mechanic, i work for a plant hire company so have a workshop etc and as i have only worked in plant hire for years, i have never bothered with learning all this computerised modern car electronics, which in situations like this it has buggered me up lol
x 5675
It may be the battery removal/replacement sequence that has caused the immobiliser problem. I had it happen to me once when I rushed the process to get to work one morning when the car wouldn't start and I put a fresh battery in. Worked OK that evening when I did it properly.
Have a look at the BSI Reset / Battery Disconnect / Reconnect Procedure and give it a shot, won't break anything and may work for you.
The Birdman
This is a list of Peugeot Planet owners from another forum , one might be near you that i can contact -
Bettyswollocks-Ballycastle,N.Ireland(plus Citroen/Vauxhall/Renault/Toyota/Honda/VW/Ford/Skoda/Nissan)
Risky - Galway, Southern Ireland
Bigboots - Southhampton, England
Catalist - Cardiff, Wales
Serbington - Woking, England
Mouse - Gloucester, England
Geoff P - Stoke-on-trent, England
stetodd - Leeds, England
steveb - Manchester,England
Robjenkins - Manchester, England
VPUG - Manchester, England
Stubbo - Crewe , Cheshire
Zooankski - Cambridge, Cambs,England
kaostheory - Fareham, south east of Hampshire, England
theblob-Leicester Leicestershire uk near junction 21 of m1
elmafudd - leicester,England
paddy69- Lancaster uk
donp- kidderminster, worcester,England
ktnch - Harrogate , England
BobT - Barnstaple. N.Devon England
Sleckonby - North Lincs, South Humberside, England
307pugpete - Rotherham , South Yorkshire, England
CMax_307 - Belfast ,Northern Ireland
CAB - Doncaster, South & East Yorkshire
teerak2uk Peterborough, Cambridgeshire, England
frankie406 - Dungannon ,Co Tyrone , N/Ireland
fruitnveg - Herefordshire, England
btsimonh - Ipswich, England
magma1974 - Plymouth , Devon , England
chrisa - Perth , Scotland (not Australia)
Gibbo - Liverpool , England.
paulofesh - Durham ,England
trimmer - Bodmin, cornwall, England
myjess - Derry , Northern Ireland
scole01234 - Maidstone , Kent , England
deksman - Durham, North East England
powelly - Abergavenny, Gwent , Wales
tiko102 - Stockport, Cheshire, England
PugLover - Gent, Belgium
DJ206 - Coventry, England
d3ck4rd - chessington, Surrey, England
matt268uk - Ringwood,Hampshire, England
JMKENT - St Austell, Cornwall, England
oldtimer - Gloucestershire, England
coupehdi - Newtownabbey, Belfast
dale2321 - Wakefield , England.
Malcolmd - Northumberland, England
danthevan - M25 Junction 6. Godstone, South London, England
freelockuk - liverpool and wirral, England
caithnesscar - northern Highlands, Lybster, KW3 6AT
richiepearce - sittingbourne kent, England
JollyRoger - Newtownards , Northern Ireland
dackjaniels - Abertillery, South Wales (I also have Galetto 1260)
danielr - South Northants - England
bcolemax - County Carlow, Southern Ireland
Michael_J - Oxfordshire/Berkshire border, England.(michaelrwjenkins@gmail.com / 07920 749 082)
m3mpower - Ex-London, England now moved to Alicante Spain.
dazwalsh - Leeds, England
markjack411 - Folkstone Kent , England
carpingtaz - Weston-Super-Mare, England
mcdig - Wigan, Lancashire, NW England
kilvo - middlesbrough, England
Rib - Dublin , Ireland
time_cop - Peterborough, Cambs, England
delvey - whitefield, manchester or Stockport, England
F4antasia - North Wales, Wrexham / Llangollen area
PeugeotBoy, Yeovil Somerset, England ( also Vauxhal OPCOM )
JordieNE - Gateshead, Tyne and Wear, England
rogersimons - i live in a little village called edwardstone just outside of sudbury suffolk , England
vodamail - Dundalk , Southern Ireland.
ultramate - Athy, County Kildare, Southern Ireland
anthony_evans - Aberdare, Rhondda Cynon Taff, South Wales
cjsgasman - North Wales - Anglesey LL65 postal code
jwestwood74 - East Tilbury in Essex
mastertech - Bicester Oxfordshire, England
jay1980 - portsmouth, England
mikezzr - newport, south wales
neo_rg - Gravesend in Kent, England
Fozzey3k - hull Bridlington and most of east yorkshire
Enright - Arnold, Nottingham, England
davidireland - Munster, Southern Ireland
bridplumber - bridlington YO15 (also galletto and op-com)
MadV - Mid Essex , England
trebor1 - skelmersdale, Lancashire, England
john_h - Gateshead , Tyne & Wear , - Ford, Mazda, Jaguar, Land Rover, Diagnostics
paulo_allen - swindon , England Galleto and PP2000
loot34 - Somewhere in Darkest Wales (Ford/Mazda ids/planet/Galetto and autel maxscan ms509)
Autofix - Swansea, South Wales Diagbox - Peugeot/Citroen IDS - Ford/Mazda/Jaguar/Landrover Vag-Com - VW/Seat/Skoda/Audi Clip - Renault Tech2 - Vauxhall Dis/Progman - BMW
Roky - Torquay
J@mes - Mapperley, Nottingham, England (Planet and op-com)
reliable406 - Falkirk, Scotland
drinud - Mellieha, Malta
Deeztheweez - Live In Addlestone Surrey work in Greenford Middlesex
Peugeot Dave - Southport , England
mozzy
peugeotboy in yeovil is the closest, 20 mins away, could you contact him and try to get a phone number ?
spider
x 77
Unread post by spider »
Did you try the BSI reset as myglaren posted above ? :) , there's no cost to this only a bit of time. It sometimes can help as above they can get 'upset' at bad batteries sometimes. I do sometimes wonder if there should of been some protection against this kind of problem, older ECU's would not be upset or corrupted by battery voltage concerns.
Andy.
mozzy
i will do it as soon as i have sourced a gearbox, its sat outside looking sorry for itself with the gearbox stripped in my workshop lol
The Birdman
mozzy wrote:peugeotboy in yeovil is the closest, 20 mins away, could you contact him and try to get a phone number ?
I`ll try [-o<
mozzy
hi there any luck
mozzy
could you try to contact carpingtaz - Weston-Super-Mare, England as he is 20 mins away from the car, car is back together now,just needs the computer work doing,
the elec issues im having are.....key light on dash flashing , elec window switches working back to front (drivers operates passenger and vice versa)....stereo has lots coding, this is evident with it beeping every few seconds.....rcl is no longer working...........i will try the bsi reset
