I sent my good lady to buy a clip & a clutch cable for my 97 Xantia TD Estate on Saturday and told her to ask if the main dealer could supply the electrical side of the ignition switch as I fear that this may be the cause of the lack of rear screen heater.
The parts man told her that Citroen only supply the complete unit with the lock barrel & new key for £130 +.
This contradicts earlier postings on this forum. Can it be true?
If not does anyone know the part number (Jon?)
I'm still stiff from doing the cable & have a couple of hints gained from this excrutiating experience:
Tape the nut from the pedal pivot to an open ended 13 mm spanner with paper masking tape. Open a hole for the bolt with a pointed tool. Pull the spanner off when the bolt is tight.
Fix the metal clip into your long nosed pliers by tightening a nylon cable clip around the handles. This helps to get the clip in place on the plastic tube.
Phil
Citroen don't sell ignition switches - True ?
muunster1
jeremy
- x 3
