Hi All
If anyone is considering a purchase I bought this one http://www.ebay.co.uk/itm/200839560291? ... 1497.l2649" onclick="window.open(this.href);return false;
and I can report that it works perfectly on my 2001 C5.
lexia purchase feed back
smokescreen
Re: lexia purchase feed back
Did you have any problems installing on your laptop and interfacing with your car. I've heard that Chinese clones sometimes throw up problems when installing.
Regards
smokescreen
Regards
smokescreen
citroenxm
- Fallen Hero
- x 70
The chineese one install fine, but its not Idiot Instructions for setting the Main Key to unlock the services.. It took me a while to understand it, but got there in the end..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
horsedentist
No all was fine took me a while to find out how to activate the software as the instructions were non existent. However the unit works a treat well worth the money and delivery was about 3 days. interfaces with car no problem clears codes allows access to technical fix pages etc no problem, came with diagbox 6.01 as well but I can't get that to work at all,also had proxia on disc but that won't install says there is a corrupt file!smokescreen wrote:Did you have any problems installing on your laptop and interfacing with your car. I've heard that Chinese clones sometimes throw up problems when installing.
Regards
smokescreen
But hey ho what do you expect for 75 quid all in all a good buy.
Mandrake
- x 694
Diagbox won't work with a 2001 C5, early C5's use the Lexia software, later models use Diagbox.
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
horsedentist
Thanks for the tip as I say couldn't get it load up anyway so never actually tried to connect it to the car just use lexia 436.22.Mandrake wrote:Diagbox won't work with a 2001 C5, early C5's use the Lexia software, later models use Diagbox.
