lexia purchase feed back
horsedentist
Unread post by horsedentist »
Hi All
If anyone is considering a purchase I bought this one http://www.ebay.co.uk/itm/200839560291? ... 1497.l2649" onclick="window.open(this.href);return false;
and I can report that it works perfectly on my 2001 C5.
smokescreen
Re: lexia purchase feed back
Unread post by smokescreen »
Did you have any problems installing on your laptop and interfacing with your car. I've heard that Chinese clones sometimes throw up problems when installing.
Regards
smokescreen
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
The chineese one install fine, but its not Idiot Instructions for setting the Main Key to unlock the services.. It took me a while to understand it, but got there in the end..
A very sad...
1994 XM 2.1 d auto
horsedentist
smokescreen wrote:Did you have any problems installing on your laptop and interfacing with your car. I've heard that Chinese clones sometimes throw up problems when installing.
Regards
smokescreen
No all was fine took me a while to find out how to activate the software as the instructions were non existent. However the unit works a treat well worth the money and delivery was about 3 days. interfaces with car no problem clears codes allows access to technical fix pages etc no problem, came with diagbox 6.01 as well but I can't get that to work at all,also had proxia on disc but that won't install says there is a corrupt file!
But hey ho what do you expect for 75 quid all in all a good buy.
x 695
Unread post by Mandrake »
Diagbox won't work with a 2001 C5, early C5's use the Lexia software, later models use Diagbox.
horsedentist
Mandrake wrote:Diagbox won't work with a 2001 C5, early C5's use the Lexia software, later models use Diagbox.
Thanks for the tip as I say couldn't get it load up anyway so never actually tried to connect it to the car just use lexia 436.22.
