fuel tank problem
ektor
fuel tank problem
Unread post by ektor »
If the fuel tank gets air inside is there any problem? if there is no air how much vacumm should be? thank you
x 94
Re: fuel tank problem
Unread post by citronut »
firstly what car/model is this,
the answer to your question is usualy no, as you can usually run an engine with the cap of,
if you do find/hear pressure escaping as you open the cap the breather/vent is probably blocked
Regards, malcolm.
spider
x 77
Unread post by spider »
I'd agree. Later petrol engines do not vent to the air (not sure about diesels actually as they don't really evaporate fuel in the same way, then again...) they have a carbon cannister arrangement.
But there should not be a mad vacuum when you release the filler cap in any case, as Malcolm has said if that happens you probably have a blocked or kinked breather pipe, easily done on some models if you've been around the tank area / had the tank out etc.
We need to know what car / year / model it is really.
Andy.
ektor
I have peugeot 206 1.9 diesel year 1999.thank you
spider
x 77
Its probably a blocked breather pipe around the tank / filler neck area then. It will be a smallish pipe.
Andy.
