Who's fitted hid's to thier 01-05 c5
stu9
x 5
Unread post by stu9 »
Cause i'm seriously thinking after tonight, i got Osram nightbreakers.....not impresred at all.....so is the next move hid. I've got them in the Pug and it's great, but it's a clear lens, the ones on the c5 are glass and ribbed so might not work as well
SaabC5
Re: Who's fitted hid's to thier 01-05 c5
Unread post by SaabC5 »
I've fitted them a couple of weeks ago, very impressed with the difference it makes. The drivers side was a real PITA to fit though, very limited space to work in. Beam pattern is fine on an MOT testing device.
stu9
x 5
You've got them and like them, the only thing that I'm not sure about is the glass ribbed lens, but you say on yours it's fine....maybe try them then, I've got other stuff to sort out too though (see other posts :roll: ) , but after being out at night, it's hellish on anything but well lit rds. But then at 135000, they've probably seen better days, I tried t cutting when I first got it, but did dam all.
SaabC5
My lens are plastic on the 02 model, not glass. I have seen plastic ones going yellow/cloudy and severely affecting visibility though. You can pick good used ones up on ebay for about £50.
stu9
x 5
Mine are too, it's the reflector that's ribbed :oops:
x 5672
The lens is degraded/yellowed by UV from the bulb and the unit needs to be fitted with non-UV bulbs.
stu9
x 5
It's not yellowed just a bit cloudy....what's non uv bulbs
x 5672
The glass envelope has UV filter characteristics.
My estate ones were awful and one of the current ones is too - car was crashed before I bought it and one of them is new. Really must get round to replacing the bad one.
lurchy666
Unread post by lurchy666 »
also be carefull what hids you buy, the cheapo hid kits from ebay land emit uv and will cloud your headlights up worse than ever, my mate found that out the hard way on his passat,
c5 2.2 auto hdi estate 52 reg
reblack68
Unread post by reblack68 »
I'm thinking of a more drastic solution to the dreadful lights on my C5. I'm planning to remove the entire headlamp unit and put something less useless in the hole. I'm not sure what yet but it will have a patterned glass lens and large reflector- as seen on page 1 of the, sadly out of print since the 1990s, "How to Design a Headlight" book.
Richard
Care of a 1994 205 D.
x 5672
Have you considered the headlight relay mod?
I was going to try it on mine then decided that the lights were OK for me, although I may use some Philips Xtreme Vision bulbs - they have (allegedly) a better beam pattern the gives more useful light than the Osram equivalents.
lurchy666
reblack68 wrote:I'm thinking of a more drastic solution to the dreadful lights on my C5. I'm planning to remove the entire headlamp unit and put something less useless in the hole. I'm not sure what yet but it will have a patterned glass lens and large reflector- as seen on page 1 of the, sadly out of print since the 1990s, "How to Design a Headlight" book.
seriously 1990's xantias are 90's cars and there headlights are terrable, much rather have something 80's with a massive lamp than theres tiny things on new cars
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
so is getting a couple of HID headlights from a scrapper an option?
Steve, I may do a voltage test on mine over weekend to see what the drop is.. and then do the relay..
My biggest problem, as had with my xantia, is the main beam seems to pool down in front of car, while the dips are just about fine...
Xantidote
x 4
Unread post by Xantidote »
jgra1 wrote:I may do a voltage test on mine
Am assuming you are talking here of the voltage drop on the feed side, but it's also worth checking the earth side as well.
I've done the relay mod on my Xantia, but only on the dip beam (rarely use main beam). This gave a noticeable improvement. Easier enough similating what the lights might be like, by taking a temporary jump wire from the battery straight to the bulb (don't short it!).
I had a small voltage drop on the earth side, but I didn't bother upgrade the wiring - the length of earth cable is not very long. However, if you were tempted to use higher wattage bulbs, then you would need to consider upgrading the earth cabling.
Martin
1995 Xantia TDLX (deceased :( )
x 5672
I maintain that the best light I have had were those on the GS!
Anyone agree/disagree?
