I have a 2002 C5 2.2 Hdi diesel estate. I want to do an engine oil change. As there is no Haynes manual could anyone tell me the correct oil to use, and the basic tips and wrinkles to do the job.
Rowland
Oil change
- x 3298
Re: Oil change
No promises that this is right for your C5, but my Xantia 2.0 HDi uses 5W40 fully synthetic. I would expect a post soon from CitroJim with all the information you need, or where to find it.
- x 1240
Re: Oil change
The C5 manual doesn't list the 2.2 but the 406 one does and that says: ACEA B3 or API CD/CF which is pretty standard oil, I use Comma from Trago Mills at about £13.00 a can.
brittleware
Re: Oil change
Low sulphur! Particulate filter risk otherwise. (ACEAB3)
Citroen 2cv
Citroen 2.5 Safari
Citroen XM 3.0 V6
Citroen XM 2.0 turbo
Fiat Ulysse 2.2Hdi
Citroen 2.5 Safari
Citroen XM 3.0 V6
Fiat Ulysse 2.2Hdi
waynedance
- x 8
Re: Oil change
There is no need for expensive low sulphur oil, I use 10/40 semi synthetic but can use fully synthetic.
Try these sites, I also called a contact at the dealer and he confirmed 10/40 semi.
http://www.commaoil.com/products/" onclick="window.open(this.href);return false;
http://www.halfords.com/webapp/wcs/stor ... _langId_-1" onclick="window.open(this.href);return false;
Volvo S80 D5.........
- x 1240
Re: Oil change
I did read somewhere that it should be low sulpher oil but it doesn't say so in either of the Haynes manuals so I use the same spec as I used in the XUD engines - that's what it says.
SaabC5
Re: Oil change
5W-40 fully synth for mine, you can get it for £20 for 5 litres in Asda or if you want to spend a little more for low sulphur try this stuff from eBay...
http://www.ebay.co.uk/itm/300637657322? ... 1423.l2649
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
411514
- (Donor 2017)
- x 39
Re: Oil change
Or
http://www.carparts4less.co.uk/cp4l/c/C ... 6ad&000398" onclick="window.open(this.href);return false;
Dont forget discount code
Sam
2003 C5 2.0HDI 110
2003 C5 2.0HDI 110
rowland420
Re: Oil change
Gentlemen,
Many thanks for all the information which is gratefully received. It seems you don't need a manual if your visit the French car forum.
Rowland
Rowland
mendedit
Re: Oil change
LOOK
http://www.citroenet.org.uk/passenger-c ... tech3.html" onclick="window.open(this.href);return false;
The world is full of them and a lot are in
