Oil change
rowland420
Oil change
Unread post by rowland420 »
I have a 2002 C5 2.2 Hdi diesel estate. I want to do an engine oil change. As there is no Haynes manual could anyone tell me the correct oil to use, and the basic tips and wrinkles to do the job.
Rowland
x 3302
Re: Oil change
No promises that this is right for your C5, but my Xantia 2.0 HDi uses 5W40 fully synthetic. I would expect a post soon from CitroJim with all the information you need, or where to find it.
x 1240
Re: Oil change
Unread post by Peter.N. »
The C5 manual doesn't list the 2.2 but the 406 one does and that says: ACEA B3 or API CD/CF which is pretty standard oil, I use Comma from Trago Mills at about £13.00 a can.
brittleware
Re: Oil change
Unread post by brittleware »
Low sulphur! Particulate filter risk otherwise. (ACEAB3)
Citroen 2cv
Citroen 2.5 Safari
Citroen XM 3.0 V6
Citroen XM 2.0 turbo
Fiat Ulysse 2.2Hdi
waynedance
x 8
Re: Oil change
Unread post by waynedance »
There is no need for expensive low sulphur oil, I use 10/40 semi synthetic but can use fully synthetic.
Try these sites, I also called a contact at the dealer and he confirmed 10/40 semi.
http://www.commaoil.com/products/" onclick="window.open(this.href);return false;
http://www.halfords.com/webapp/wcs/stor ... _langId_-1" onclick="window.open(this.href);return false;
Volvo S80 D5.........
C5 2.2HDi Exclusive 2003 manual (now gone).
2009 Renault Megane, the misses drive.
Had a 1988 BX 19TRS Auto many moons ago.
Forgive any spelling mistakes, it's the phone not me.
x 1240
Re: Oil change
I did read somewhere that it should be low sulpher oil but it doesn't say so in either of the Haynes manuals so I use the same spec as I used in the XUD engines - that's what it says.
SaabC5
Re: Oil change
Unread post by SaabC5 »
5W-40 fully synth for mine, you can get it for £20 for 5 litres in Asda or if you want to spend a little more for low sulphur try this stuff from eBay...
http://www.ebay.co.uk/itm/300637657322? ... 1423.l2649
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour) :wink:
411514
(Donor 2017)
x 40
Re: Oil change
Unread post by 411514 »
Or
http://www.carparts4less.co.uk/cp4l/c/C ... 6ad&000398" onclick="window.open(this.href);return false;
Dont forget discount code
Sam
2003 C5 2.0HDI 110
rowland420
Re: Oil change
Gentlemen,
Many thanks for all the information which is gratefully received. It seems you don't need a manual if your visit the French car forum.
Rowland
mendedit
Re: Oil change
Unread post by mendedit »
LOOK
http://www.citroenet.org.uk/passenger-c ... tech3.html" onclick="window.open(this.href);return false;
The world is full of them and a lot are in
