Electric seats front stuck on high crushing legs
sprout
Unread post by sprout »
Hi all,
Citroen xantia 2.0 HDi Exclusive 1999 V plate
I have been suffering with back pain for a while and thought I would have a play with the multitude of adjustments available :)
Should have left it, I raised the front to fully up and there it has stayed :oops:
All other electric functions back up, forward, backwards, lumber etc still fine.
It's dark out now so will have a look tomorrow, NOT what I need at all really climbing and bending around on the floor, it will probably finish my back off all together :(
So to go out armed is there an orderly check list to help me along please?
i.e. each motor fused separately or grouped?
Motors fail (No noise when switch activated)
Connectors etc
Thanks in advance
Current: C5 2008 2.0HDi Auto Exclusive (Ireland born) + VW Touareg V10
Previous Cits: CX2000, BX 1.9L, BX 16V, Xant VSX TD, Xant 2.0HDI (110) Exclusive
Some others: Fords1600E, Capri 3000GXL, Granada Scorpio, Mitubishi Starion Saab's 900, 900 Turbo, 9000 Aero, 2 Jeeps
citroenxm
Fallen Hero
x 70
Re: Electric seats front stuck on high crushing legs
Unread post by citroenxm »
My car suffers this.. Its an identical one, V reg Exclusive etc.. I have my seat on a front up tilt and rear down setting, however, some days it wont adjust back, then others it works fine...
Im only the one that drives mine really, so rarely need to adjust the seat, so it doesnt bother me really.
A very sad...
1994 XM 2.1 d auto
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
If when you move the switch the motor doesn't run then I'd look towards the switch as they are relatively fragile, reach under/behind the switch and push it out, you may find that one of the rollers has popped out of place, if however the motor is running but nothing is happening to the seat height then the culprit is more than likely the splined rod which runs across the seat has either popped out of the motor or stripped its splines, the bad news is that the splined rod isn't available separately, the good news is that I've got a brand new whole seat base including motors and rods,,,
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 1240
Unread post by Peter.N. »
I would concur, used to be quite a common occurance on XMs, try squirting some WD40 into it and giving it a good workout.
sprout
citroenxm wrote:My car suffers this.. Its an identical one, V reg Exclusive etc.. I have my seat on a front up tilt and rear down setting, however, some days it wont adjust back, then others it works fine...
I would not worry overly if my back was not moaning.
However the wife drives this more than me.
DickieG wrote:If when you move the switch the motor doesn't run then I'd look towards the switch as they are relatively fragile, reach under/behind the switch and push it out, you may find that one of the rollers has popped out of place, if however the motor is running but nothing is happening to the seat height then the culprit is more than likely the splined rod which runs across the seat has either popped out of the motor or stripped its splines, the bad news is that the splined rod isn't available separately, the good news is that I've got a brand new whole seat base including motors and rods,,,
Cheers, the motor is not running so will go with the first part of your advice first 8-)
Peter.N. wrote:I would concur, used to be quite a common occurance on XMs, try squirting some WD40 into it and giving it a good workout.
Hopefully it will be cured soon :)
Thanks for all your comments and I will update when I have had a look.
Cheers
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Try gently wiggling the control lever near the end of its travel. Oftentimes you'll find that holding it a poofteenth away from it's inbuilt stop, will result in good contact and resultant motor action.
