Yes you can Mike...
The wires you need to connect are the big heavy yellows to the positive and the heavy green/yellow ones to the negative.
I recommend you connect via a 30A fuse for safety.
You must be able to motor the seats back and forth to allow their installation.
Electric seats
- x 8448
Re: Electric seats
citroenxm
- Fallen Hero
- x 70
Re: Electric seats
Shame.. if the car was a Series 2 Sx model then it would be a doddle .. and soo simple because they have the plugs all ready under the seats ready for electric seats...
not sure about late activas though...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
DickieG
- Monaco's youngest playboy
- x 33
Re: Electric seats
Yes I'd use croc clips for the installation, the plugs/sockets are different but you can replace those with crimps or solder them together, S2 seats into a S1 re pretensioners do work OK well as far as putting the dash light out, I haven't felt the need to test them on impactsuperloopy wrote:Cheers Jim, I'm only using a spare battery to install and adjust so I'd not need a fuse, yes? Couple of croc clips on those wires you've identified should be enough to get me up and running. Just thought, will I be able to make the other connections to pretensioners?, not the airbags cos they're s2 seats into an s1.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
