Electric seats
x 8358
Re: Electric seats
Yes you can Mike...
The wires you need to connect are the big heavy yellows to the positive and the heavy green/yellow ones to the negative.
I recommend you connect via a 30A fuse for safety.
You must be able to motor the seats back and forth to allow their installation.
citroenxm
Fallen Hero
x 70
Re: Electric seats
Unread post by citroenxm »
Shame.. if the car was a Series 2 Sx model then it would be a doddle .. and soo simple because they have the plugs all ready under the seats ready for electric seats...
not sure about late activas though...
A very sad...
1994 XM 2.1 d auto
DickieG
Monaco's youngest playboy
x 38
Re: Electric seats
Unread post by DickieG »
superloopy wrote:Cheers Jim, I'm only using a spare battery to install and adjust so I'd not need a fuse, yes? Couple of croc clips on those wires you've identified should be enough to get me up and running. Just thought, will I be able to make the other connections to pretensioners?, not the airbags cos they're s2 seats into an s1.
Yes I'd use croc clips for the installation, the plugs/sockets are different but you can replace those with crimps or solder them together, S2 seats into a S1 re pretensioners do work OK well as far as putting the dash light out, I haven't felt the need to test them on impact :lol:
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
