cheap key cutting
john
cheap key cutting
Unread post by john »
i changed the lock on my 'lingo a while back, the set i got only came with 1 key however, ive now decided to get a spare cut just incase, ive still got the transponder chip from my "original spare" so just need a blade with a bit for holding the chip.
anyone know somewhere cheap that could supply and cut the key?
Citroen Xsara Picasso
Subaru Impreza WRX
Nissan Primastar
x 8422
Re: cheap key cutting
Some high street locksmiths can do the job. If they carry blanks then they should be OK to cut them. I take it the 'Lingo uses the same cruciform key as other Citroens of the era...
I had a spare Xantia key successfully cut by our local locksmith even if he did declare he hated doing them!!!
john
think it's a similar key, perhaps I should have mentioned the locks got changed and it now has a pug partners locks, similar if not identical setup to the Citroen though.
Subaru Impreza WRX
Nissan Primastar
Old-Guy
x 32
Unread post by Old-Guy »
Mr Minit
lurchy666
Unread post by lurchy666 »
i got my spare key for my xantia done from http://www.carkeyhelp.co.uk/" onclick="window.open(this.href);return false; ( send them a pic of your key and they cut it from that) then you just need someone with lexia to proramme it for you
c5 2.2 auto hdi estate 52 reg
