i changed the lock on my 'lingo a while back, the set i got only came with 1 key however, ive now decided to get a spare cut just incase, ive still got the transponder chip from my "original spare" so just need a blade with a bit for holding the chip.
anyone know somewhere cheap that could supply and cut the key?
cheap key cutting
john
cheap key cutting
Citroen Xsara Picasso
Subaru Impreza WRX
Nissan Primastar
Subaru Impreza WRX
Nissan Primastar
- x 8422
Re: cheap key cutting
Some high street locksmiths can do the job. If they carry blanks then they should be OK to cut them. I take it the 'Lingo uses the same cruciform key as other Citroens of the era...
I had a spare Xantia key successfully cut by our local locksmith even if he did declare he hated doing them!!!
john
think it's a similar key, perhaps I should have mentioned the locks got changed and it now has a pug partners locks, similar if not identical setup to the Citroen though.
Subaru Impreza WRX
Nissan Primastar
Subaru Impreza WRX
Nissan Primastar
Old-Guy
- x 32
Mr Minit
lurchy666
i got my spare key for my xantia done from http://www.carkeyhelp.co.uk/" onclick="window.open(this.href);return false; ( send them a pic of your key and they cut it from that) then you just need someone with lexia to proramme it for you
c5 2.2 auto hdi estate 52 reg
