AL gear box plug
Sam KS
AL gear box plug
Unread post by Sam KS »
any one know if the filler plug requires one of those special plug tools and if so what size? also sump plug and filler plug washer sizes? planing on doing ATF change this weekend and forgot about getting things ready till now.
Citroën Xantia 75th Anniversary Limited Edition
addo
Sara Watson's Stalker
x 95
Unread post by addo »
8mm square drive for the top plug; maybe 14mm crush washer?
Bottom is 27mm outer from memory, inner maybe 22mm. They (on mine) have viton-lipped washers you don't need to replace.
Sam KS
Re: AL gear box plug
Thanks, I have the washers in the shed. just need to pick up a 8mm square drive tomorrow.
Clogzz
x 40
Unread post by Clogzz »
A door lock shaft is 8 mm square.
Bunnings sell them separately.
I got a nut welded onto it at taxpayers’ expense by a teacher at a part-time welding school near my old scrap of work.
The filler plug has no washer.
The drain washers are as per addo and I don’t replace them.
Image Image
2002 C5 2.0i AL4 239,000 km 76372389
Sam KS
I'll be in Bunnings today. will pick one up and get a customer to weld it for me later.
x 8176
Sam KS wrote:I'll be in Bunnings today.
Bunnings. That brings back memories :-D
addo
x 95
I'm waiting for him to fill the gearbox with 4711. Smells nice, y'know?
x 8176
Re:
addo wrote:I'm waiting for him to fill the gearbox with 4711. Smells nice, y'know?
Well, it's nearly right isn't it :lol:
Sam KS
WOW, 4711. My sister used to use that.
addo
x 95
Did it work? :lol:
x 8176
Sam KS wrote:WOW, 4711. My sister used to use that.
Good job she didn't use 71141 Sam :lol: Unless of course she likes the smell of eau d'cat and caramelised toast...
x 8176
Re:
addo wrote:Did it work? :lol:
Ahh! I see it's insomnia time for the Aussie contingent. Payback for having to suffer the insomniac Poms earlier I guess Adam :lol:
addo
x 95
Nah; only 2100H here (DST) and I'm having trouble staying awake.
One day I'll show you blokes my "party trick" - which is, going to sleep within three breaths lying almost anywhere.
x 8176
Re:
addo wrote:which is, going to sleep within three breaths lying almost anywhere.
:lol:
I used to be able to that Adam. I used to joke I could instantly fall asleep anywhere; up to and including a railway line... :twisted:
Not any more. For all the use my bed is I'd may as well sell it :(
addo
x 95
Ha! I have performed that trick (almost) by sleeping on the bitumen platform at a busy railway station.
forgetdinner.co.uk doesn't float your boat? :shock:
