AL gear box plug
Sam KS
AL gear box plug
any one know if the filler plug requires one of those special plug tools and if so what size? also sump plug and filler plug washer sizes? planing on doing ATF change this weekend and forgot about getting things ready till now.
Citroën Xantia 75th Anniversary Limited Edition
addo
- Sara Watson's Stalker
- x 95
Sam KS
Re: AL gear box plug
Thanks, I have the washers in the shed. just need to pick up a 8mm square drive tomorrow.
Clogzz
- x 40
A door lock shaft is 8 mm square.
Bunnings sell them separately.
I got a nut welded onto it at taxpayers’ expense by a teacher at a part-time welding school near my old scrap of work.
The filler plug has no washer.
The drain washers are as per addo and I don’t replace them.
Sam KS
I'll be in Bunnings today. will pick one up and get a customer to weld it for me later.
- x 8389
Bunnings. That brings back memoriesSam KS wrote:I'll be in Bunnings today.
addo
- x 95
Sam KS
WOW, 4711. My sister used to use that.
- x 8389
Good job she didn't use 71141 SamSam KS wrote:WOW, 4711. My sister used to use that.
addo
- x 95
- x 8389
Re:
addo wrote:which is, going to sleep within three breaths lying almost anywhere.
I used to be able to that Adam. I used to joke I could instantly fall asleep anywhere; up to and including a railway line...
Not any more. For all the use my bed is I'd may as well sell it
addo
- x 95
