The remote central locking doesn't work on my newly acquired C5 2.0 Hdi (yesterday) it locks from the door but not from the fob, I have had a look inside and it seems to have a very simple PCB compared with the XM, the battery is reading 2.85v which I would have thought was enough. I have heard comments about syncing them, could that be the problem or do I have a fault?
Peter.
C5 remote
SaabC5
Re: C5 remote
Try putting the key into the ignition and turning it to live but not starting the car, then press and hold the lock button for approx 10 secs. Turn the ignition off, and see if it now locks with the plip.
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
- x 1240
Re: C5 remote
Thanks for the suggestion, tried it but still doesn't work.
oneday
Re: C5 remote
hi just done mine on the lexia recoded both keys then it allows you to reload the fobs
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
reblack68
Re: C5 remote
I got mine working by turning the ignition on and pressing each button in turn.
Richard
Care of a 1994 205 D.
Richard Stevens
Re: C5 remote
Funny old world, just got the same problem on mine. I was away at the time (yesterday) and thought the battery had given in, but tried my spare today with the same result. Tried the key in, ignition ON thing, but no cigar. - To my garage next for a reprogramming, I guess.
Seems there is a bit of experience with these - that's a surprise.
1995 ZX Turbo diesel Volcane
1999 Xantia HDI
2005 C5 1.6 HDI
2006 C5 2.0 HDI Exclusive
Remember - many warnings are spurious or bad connections
1999 Xantia HDI
2005 C5 1.6 HDI
- x 1240
Re: C5 remote
Still haven't been able to sort mine out, I will have a go at it with the Lexia when I find out how.
oneday
Re: C5 remote
go into key programming do all keys then it will allow you to do the fobs with the instructions
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
oneday
Re: C5 remote
remember follow instruction dont start engine untill finished or it wont let you do the fobs
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
GB
Re: C5 remote
Had the remote central locking problem with my 54-reg C5 last year.
First I thought it was the remote battery, replaced it to no avail.
What finally fixed it was disconnecting the car battery for ten minutes.
05 C5 VTR 2.0 HDI
115k
115k
- x 1240
Re: C5 remote
How do I get into 'key programming'?
oneday
- x 1240
Re: C5 remote
Ah thank you, I'm still a novice at this.
hmvt
Re: C5 remote
I had that problem last month and solved using the key in the drivers door lock.
After that the problem was solved...
