Induction problem
Post Reply
Jaine
My Cars:
Induction problem
Post by Jaine »
I put a K&N 57i induction on my 205 1.6gti & it is quite kangarooey (good word) up to about 3500rpm but better on fast acceleration. This is the only car I have ever had run a bit rough after fitting one of these.
Any advice please?
Jaine :oops:
If I throw a stick, will you leave?.
spider
My Cars: Soon, I hope...
x 77
Contact:
Re: Induction problem
Post by spider »
You may have to increase the mixture slightly to compensate for the increase in air although I'd stick the stock air filter back quickly to check its nothing else first, you may of caught a wire or dislodged something. :) I'd do this myself before attempting any adjustment just in case something else is amiss.
Andy.
Jaine
My Cars:
Post by Jaine »
Just in the process of changing it back to see if it is anything else before I blame the K&N.
Also the only one I have had no induction noise from at all. Had them on all 3 Williams & got a lovely racket!
Thanks for advice, will update shortly
Jaine
Jaine
My Cars:
Post by Jaine »
Standard filter back on & ticks over perfect again, just about to take her for a run & see how she goes.
Jaine
My Cars:
Post by Jaine »
No, car still kangarooey, just not as obvious with standard filter, so K&N back on & look at the mixture.
Jaine
My Cars:
Post by Jaine »
K&N back on, still rough, mixture checked so booking into Atspeed racing soon to get it all checked out.
jgra1
(Donor 2021)
My Cars: 2010 C5 X7 2.0 hdi 160 exc auto
MG TF 135
Boxer II 2.2 camper conversion
BMW R1200RT
BMW K1300 R
Honda V F R 800 5thG / MT500 Armstrong
x 39
Post by jgra1 »
let us know how it went :) or rather, how it goes..
John
addo
Sara Watson's Stalker
Location: NEW South Wales, Australia. I'll show you "Far, far away" ;-)
My Cars: Peugeot 605
Citroën Berlingo
Alfa 147
x 93
Post by addo »
I think it's because the airflow "develops" into quite a distinct stream that can influence the airflow meter. There's a few ways to address that.
Junkman
My Cars:
x 3
Contact:
Post by Junkman »
Looking at the stock 205 GTI intake, it seems to be engineered for calming the airflow in three places, also it sucks in cold air.
Looking at the K&N Setup, there is no airflow calming whatsoever, and it sucks in hot air.
I suspect it confuses your MAP. Pull the plug off the sensor and see how it runs then.
1994 Peugeot 405 GTX 2.0 auto estate
1992 Citroen BX 19 TXD estate
Jaine
My Cars:
Post by Jaine »
OK I will, I have placed the cold air feed directly onto it though & the filter does sit at the front now instead of directly over the manifold.
Let ya know.
Post Reply
