LEXIA
C8misery
LEXIA
Unread post by C8misery »
Does anyone else's lexia just read the ignition and headlight ecu's?
Thats all mine will read everything else just has a no in the read column?
Can anyone help?
x 8418
Re: LEXIA
Are you giving the Lexia the full and correct VIN and RP number...
I've seen this happen if the VIN and RP number are entered as strings of Zeros rather than the correct values.
Have you tried your Lexis on another car?
What Lexia is it?
C8misery
Re: LEXIA
Thanks for the reply.
It recognises the vin correctly itself...rpo number I just used string of 1's.
Nobody I know has a citroen would you believe it!!
It is a chinese ebay clone Lexia running 3.45 software.
I will try it again with the correct rpo see if that makes a difference. Thanks
x 8418
Re: LEXIA
Yes, because it often uses the RP number to determine the type of ECUs fitted.
Sometimes you get away with all zeros or 1s but often you don't. Hope that works...
The Birdman
Re: LEXIA
Unread post by The Birdman »
I can get you your RPO number if you send me your Vin Number
For what we are about to receive may we be truly thank full.
http://www.citroencodes.com" onclick="window.open(this.href);return false;
http://www.peugeotcodes.com" onclick="window.open(this.href);return false;
C8misery
Re: LEXIA
Big thanks to Citrojim, yep putting in my RPO solved it....Lexia now working great...apart from my rt3...
Thanks for the offer The Birdman....I signed up on the citroen service site....very useful!!
