Does anyone else's lexia just read the ignition and headlight ecu's?
Thats all mine will read everything else just has a no in the read column?
Can anyone help?
LEXIA
- x 8422
Re: LEXIA
Are you giving the Lexia the full and correct VIN and RP number...
I've seen this happen if the VIN and RP number are entered as strings of Zeros rather than the correct values.
Have you tried your Lexis on another car?
What Lexia is it?
What Lexia is it?
C8misery
Re: LEXIA
Thanks for the reply.
It recognises the vin correctly itself...rpo number I just used string of 1's.
Nobody I know has a citroen would you believe it!!
It is a chinese ebay clone Lexia running 3.45 software.
I will try it again with the correct rpo see if that makes a difference. Thanks
The Birdman
Re: LEXIA
I can get you your RPO number if you send me your Vin Number
For what we are about to receive may we be truly thank full.
http://www.citroencodes.com" onclick="window.open(this.href);return false;
http://www.peugeotcodes.com" onclick="window.open(this.href);return false;
