Xantia engine mounts
Stekelly
Unread post by Stekelly »
I'm failry sure I've a knackered enine mount on the 1.8 and after 12 years I reckon I'll just change them all. Looking at the likes of Eurocarparts and theres a few listed . How many mounts are there in total would be great if anyone knows.
Had a look at an Irish site too and they list 5 . A right ,left and rear. Two are listed as rear axle though. The options are QH or first line. Is it much of a muchness when it comes to these sort of things or should I be looking at a better name?
Not sure if it will work but this is the list I'm working off. http://www.micksgarage.com/engine-parts ... -16v/9078/" onclick="window.open(this.href);return false;
Cheers
jgra1
(Donor 2021)
x 36
Re: Xantia engine mounts
Unread post by jgra1 »
shame I have the gearbox one on my desk in front of me right now, brand new.. and in need of a home..
there are 3 normally.. but I have a feeling some xants (v6? Hdi?) may have a fourth in the form of a torque link, going from the head to bulkhead..
J
Stekelly
jgra1 wrote:shame I have the gearbox one on my desk in front of me right now, brand new.. and in need of a home..
J
Problem with being in Ireland is it would probably cost the price of it to post it.
Was thinking 3 alright, thats what most sites seem to list.
jgra1
(Donor 2021)
x 36
yeah 3 for sure on the 1.8 :)
Stekelly
Cheers , so am I right with FEM 3234. 3243 and 3246 off the list? http://www.micksgarage.com/engine-parts ... -16v/9078/" onclick="window.open(this.href);return false;
charentejohn
Unread post by charentejohn »
I found my OEM part nos from good old http://service.citroen.com/" onclick="window.open(this.href);return false; Lots of posts here on how to use it. You can put in your Vin no and it goves you the real ones, you can then check with the suppliers. If you aren't sure then post your Vin no here, or PM me if you prefer and we can look it up for you.
Mine arrived a few weeks ago, just got to get on with it now. A friend made me two small metal cylinders I am hoping to use to push out the bottom joint, one larger than the bush and one slighly smaller, to be used with a threaded bar. May not work but easier than removing the driveshaft.
You must be the change you want to see in the world - Mahatma Gandhi
Xantia HDI 90SX C3 2005 and C3 2006 both 1.4i sensodrives
