I have a 1995 AX 1.5D
I recently had to change the heater blower, and to do so I loosened the entire dash, and took the fusbox out, and took the blower down into the footwell.
It was VERY tight. In doing so, I damaged a toggle switch that was BEHIND the dash, down near the fusebox. The cable ran from the ignition area, to the switch, and out the bulkhead into the engine..... and into a "thing" at the front of the engine, an unwieldy metal cylinder which had the accelerator cable attached to it and lots of other stuff. Not sure of the exact term.
Anyway, seeing as the switch was behind the dash, it looked like an aftermarket installation, any idea what it could be doing? TBH it looked like the item in the engine should always have had a wire there, perhaps something broke and the toggle switch was a botched fix or something... I dunno.
It wouldn't be an override for the glow plugs would it???
Thanks.
odd switch on AX diesel
3ps
Re: odd switch on AX diesel
Meant to add... while removing the blower I damaged the switch and it's definitely not working, but everything seems to work as normal.
aerodynamica
- x 215
Might be an immobiliser fitted after market by a previous owner.
Graeme M
spider
- x 77
Would need to see a picture of the item in the engine bay you do not identify and the switch area too.
At a guess its either a manual control for the blower motor (although these don't suffer with the burned ignition switch problem as far as I know) or possibly something simple like an immobiliser.
The latter seems more likely to be honest given its partly hidden away too.
Andy.
lurchy666
accelorator cable, well on an ax diesel thats gotta be the desel pump aint it, its probaby a immobilser of sorts onto the stop solinoid,
c5 2.2 auto hdi estate 52 reg
3ps
Yes a hidden switch link to the ignition does sound like an immobiliser and I obviously broke it in the OFF position, luckily!
Will report back if it causes problems.
I only ask as I have been having starting probs recently and I thought it might be a glow plug timer thing or related. I'll start another thread on that.
lurchy666
ok ive attached a picture of an ax diesel egine ok its a 1.4 nstaed of a 1.5 but its all i could find, does the cable go to the bit ive circled in picture f it does id say its definalttly a immobiliser of sorts, hope ths helps
- Attachments
- ax engine
