Xsara windscreen wiper motor assembly
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
Have just had one of the daughters on the phone this evening. She was driving home on the M23 in heavy rain when the wipers suddenly stopped working. She reports a graunching noise so presumably the motor is still working. Are there any replacable parts in the motor or is it better to source a complete assembly from a yard? Also how difficult a job is it?
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
uncle buck
x 10
Re: Xsara windscreen wiper motor assembly
Unread post by uncle buck »
I've never done the job on the Xsara but I have on other cars, it's normally not that difficult.....Famous last words :-D
Remove the wiper arms from the spindles then the plastic panel that sits at the bottom of the windscreen to gain access to the wiper rack.
The wiper spindles can become tight in their sockets due to corrosion, these come apart and you can clean them up and re grease them. The linkages are normally a ball & socket affair so these also can be lubricated.
I think I would have a look at the rack before I went and got one from the scrappy as the one one the car may just need a bit of fettling.
Good luck.
2006 C4 1.6 HDi 16V (92) non FAP
2001 Xsara II 1.4 LX
2001 Renault Laguna II 1.9dCi Sport Tourer
JohnD
(Donor 2022)
x 72
Right! I've got the assembly off the car and one of the ball joints has come apart. It pushes back together again but it wouldn't take much for it to come adrift again. Anybody know if it's possible to make a more permanent repair.
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
JohnD
(Donor 2022)
x 72
Since nobody has any experience of repairing faulty ball joints, I've concluded that it doesn't often happen so have gone for a breaker's one. I found a suitable assemby on ebay for £28 icluding P&P. Job done!!
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
Xantidote
x 4
Unread post by Xantidote »
Hi John, just curious. Was the ball rusty and corroded, or a lack of lubrication, or a worn plastic socket perhaps?
Martin
1995 Xantia TDLX (deceased :( )
JohnD
(Donor 2022)
x 72
The ball seems to have rusted away. There was certainly a lot of rust in the socket, but nothing to hold it together.
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
