Paint code ?
HDI
x 7
Paint code ?
Unread post by HDI »
The paint code for a Xantia is said to be a 3 letter code but on the door post sticker of my HDi it's 4 letters, KPKD. I can find KPK touch up paint but not KPKD, does the D matter ?
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
x 8422
Re: Paint code ?
KPK is the shade part which is Mauritius Blue...
The D I believe refers to the kind of finish. I would imagine the D is normal metallic. Exclusives seem to have CR as the finish which i understand to be pearlescent metallic. As an example New V6 has a paint code of KPKCR - Mauritius Blue Pearlescent.
So, your KPK touch-up should be fine. it's flat so any touching up will require an overcoat of clear lacquer.
oneday
Re: Paint code ?
Unread post by oneday »
or it could be the colour of the undercoat
306 1.4 LX MERIDIAN
x 8422
Re: Paint code ?
superloopy wrote:Reply retracted, untrustworthy :sad:
You know Mike, I was just thinking up the most polite and diplomatic way to say something about your last post. You've saved me task now :lol: :lol: Thanks! that's eased the load on my brain no end...
Polite and diplomatic I'm not sadly - never a skill I managed to master :(
x 8422
Re: Paint code ?
:lol: Admins are ever vigilant Mike :wink: :lol:
superloopy wrote: (i'm still busy 'researching' this one because i'm sure i've read that the fourth character is a factory identifier :? )
Ahh yes, it's the two lettetrs after the RP Number that shows where the car was born...
Look at the RP and it'll be say, 7571CJ if it's a Xantia hatch. The CJ bit indicates it was built in Alnuay Sans Whatsit. Xantia Estates were built by Heiulitz and have a different two letter identifier after the RP number...
Somewhere on this forum is a list of plants and their codes...
x 8422
Re: Paint code ?
superloopy wrote: Curtain up .... i'm back on stage :-D
With a flourish Mike =D> =D>
Excellent :-D
So D then is the same as the earlier CR code which means say KPKCR and KPKD are one and the same Mauritius Blue Pearlescent...
x 8422
Re: Paint code ?
Oh and Paint Code KJAPL is what my Activa currently has; where KJA is Dantes' Red and PL is Peeling Lacquer :(
x 5674
Re: Paint code ?
Maybe the lacquer is meant to peel off for customers who want a matt finish without resorting to emulsion and a roller.
trucker1
Re: Paint code ?
Unread post by trucker1 »
On C5 only first three letters used good match on my C5 paintwork. halfords swansea first class 2 days from local cit dealers lol
2002 c5 sx hdi
