Paint code ?
HDI
- x 7
Paint code ?
The paint code for a Xantia is said to be a 3 letter code but on the door post sticker of my HDi it's 4 letters, KPKD. I can find KPK touch up paint but not KPKD, does the D matter ?
Now using '00 Xantia LX HDI, pov spec
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident
'99 Xantia HDI 110 Exclusive, RIP
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped
& a couple of Peugeots !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
- x 8422
Re: Paint code ?
KPK is the shade part which is Mauritius Blue...
The D I believe refers to the kind of finish. I would imagine the D is normal metallic. Exclusives seem to have CR as the finish which i understand to be pearlescent metallic. As an example New V6 has a paint code of KPKCR - Mauritius Blue Pearlescent.
So, your KPK touch-up should be fine. it's flat so any touching up will require an overcoat of clear lacquer.
oneday
Re: Paint code ?
or it could be the colour of the undercoat
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
- x 8422
Re: Paint code ?
You know Mike, I was just thinking up the most polite and diplomatic way to say something about your last post. You've saved me task nowsuperloopy wrote:Reply retracted, untrustworthy
Polite and diplomatic I'm not sadly - never a skill I managed to master
- x 8422
Re: Paint code ?
Ahh yes, it's the two lettetrs after the RP Number that shows where the car was born...superloopy wrote: (i'm still busy 'researching' this one because i'm sure i've read that the fourth character is a factory identifier)
Look at the RP and it'll be say, 7571CJ if it's a Xantia hatch. The CJ bit indicates it was built in Alnuay Sans Whatsit. Xantia Estates were built by Heiulitz and have a different two letter identifier after the RP number...
Somewhere on this forum is a list of plants and their codes...
- x 8422
Re: Paint code ?
With a flourish Mikesuperloopy wrote: Curtain up .... i'm back on stage
Excellent
So D then is the same as the earlier CR code which means say KPKCR and KPKD are one and the same Mauritius Blue Pearlescent...
- x 8422
Re: Paint code ?
Oh and Paint Code KJAPL is what my Activa currently has; where KJA is Dantes' Red and PL is Peeling Lacquer
- x 5675
Re: Paint code ?
Maybe the lacquer is meant to peel off for customers who want a matt finish without resorting to emulsion and a roller.
trucker1
Re: Paint code ?
On C5 only first three letters used good match on my C5 paintwork. halfords swansea first class 2 days from local cit dealers lol
2002 c5 sx hdi
