C5 electric questions
jgra1
(Donor 2021)
x 37
Unread post by jgra1 »
chaps, following on from my blog posting..
Q1
do I need to enable electric leather in my C5 for it to work? - with a lexia I dont have :(
(the fuses are there, but when plugged in, nothing is happening)
cheers
J
x 5673
Re: C5 electric questions
Have you put a shilling in the meter John?
jgra1
(Donor 2021)
x 37
steve ;) thats not helping
half way through job and dont know if i should abandon..
checked under bonnet fuses - all there
x 5673
I believe others that have done it have said that a Lexia wasn't required to initialise them.
Electric seat fuses are on page 131 of the handbook.
Under dash fuses G37-40
x 5673
Ah! it did post. Just as I pushed the submit button the power cord pulled out of the laptop and it died.
x 1240
Unread post by Peter.N. »
I am in the process of doing this myself and if I understand correctly it requires an 80 amp maxi fuse underneath the main fuseboard. I haven't looked under mine yet but I have some fuses on order, very cheap on ebay.
Citroenmad
x 110
Unread post by Citroenmad »
As far as I know its not been a problem others have found when fitting electric leather to a C5. However I have noticed that there is an option in the Lexia menus for electric seats. I guess you will soon find out, just have a few cushions ready incase its not at your desired driving position :lol:
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
jgra1
(Donor 2021)
x 37
lol
well i checked i had the 40 amps in the glovebox area
and I looked under bonnet and could see no gaps in that fuse box
old ones going back in ;( for now..
but will take a look under the fusebox quickly peter ;)
x 1240
You apparantly can't see this 80a fuseholder until you remove the engine bay fuse board, its underneath at the front I am told.
jgra1
(Donor 2021)
x 37
I tried Peter ... but it was getting dark, and I started to see PCB's that I really shouldn't have and panicked..
I put all back together and the car wouldn't start :)
shut and locked and unlocked car and all ok again .. phew..
Will try and work out how to get under the engine bay fuses tomorrow evening..
old front seats back in, new beige carpet fitted and a bit of walnut stuff here and there :)
jgra1
(Donor 2021)
x 37
problem 2
well, I quite easily pulled the fusebox up and stuffed the only maxi I had in to socket 61, a 50A
all working ;) seats in.. doors cards x 2 done..
but
car has gone into economy mode!
read the manual, said start car.. which I can't as it seems that the immob (aftermarket alarm) has gone to sleep.. when I lock the doors the lights don't flash..
ideas? I guess a careful battery disconnect? (will read Steve's post)
jgra1
(Donor 2021)
x 37
didn't work.,.
car is dead it seems.. starter works but wont fire..
grrr
x 5673
Did you go through the battery disconnect/reconnect routine.
If you take any shortcuts it can screw up the immobiliser.
Patience is the answer.
jgra1
(Donor 2021)
x 37
well I turned all off.. waited.. then took terminals off and ran a bulb between them, then bridged them
then waited..
Maybe I didnt wait long enough after I reconnected.. and of course I cant open drivers window as all windows seem to be off due to eco mode?
I have disconnected again now, and am charging battery (it was 12.5 however)
car is unlocked, windows shut..
looks like a train to work tomorrow for the first time ever :( ...
Citroenmad
x 110
C5s do very strange things when the battery is getting low.
We found for a while that if weh had the doors open for a long time on our C5 estate it would then fail to start. It would go into economy mode but that doesn't seem to do much! The starter would spin the engine round quickly but it wouldnt start the engine. As it has an alarm we also found the alarm would go off some times, in fact I think there is a back up batter for the alarm, as once the batter was totally flat but the alarm was going off.
Charging the batter got the car started, often on its first start the power steering would not be functional. After a restart it was back to normal. A new batter cured this non starting problem and it has never returned.
Do you not have a batter charger?
03 Seat Arosa 1.0S
